[Qgis-user] Combine raster bands in Graphical Modeller
Richard McDonnell richard.mcdonnell at opw.ie
Tue Oct 3 05:30:28 PDT 2023
Hi Grant,
The syntax is as follows...
For three separate single band Images....
-A input1.tif --A_band=1 -B input2.tif --B_band=1 -C input3.tif --C_band=1 ...........
For a single raster multiple bands...
-A input1.tif --A_band=1 -B input.tif --B_band=2 -C input.tif --C_band=3 ..........
I hope that helps and hope the process works!
Kind Regards,
Richard
Richard McDonnell MSc GIS, FME Certified Professional
FRM Data Management
Oifig na nOibreacha Poiblí
Office of Public Works
Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 46 942 2409
https://gov.ie/opw
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
https://https://gov.ie/opw<https://www.opw.ie>
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/<https://www.opw.ie/en/disclaimer/>
From: boxerg at iinet.net.au <boxerg at iinet.net.au>
Sent: 03 October 2023 13:05
To: Richard McDonnell <richard.mcdonnell at opw.ie>
Subject: RE: [Qgis-user] Combine raster bands in Graphical Modeller
Hi Richard,
Yes, I have thought about that by putting it in the gdal command, but not sure of the correct syntax.
Cheers Grant
From: Richard McDonnell <richard.mcdonnell at opw.ie<mailto:richard.mcdonnell at opw.ie>>
Sent: Tuesday, October 3, 2023 7:15 PM
To: Grant Boxer <boxerg at iinet.net.au<mailto:boxerg at iinet.net.au>>
Cc: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Hi Grant,
I have not tied it, but one possible solution is to use the additional command -line parameters to specify the Bands, it might be worth a try..
Kind Regards,
Richard
FRM Data Management
https://gov.ie/opw
From: QGIS-User <qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>> On Behalf Of Grant Boxer via QGIS-User
Sent: 03 October 2023 04:48
To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Combine raster bands in Graphical Modeller
I have a multiband raster and I need to add all the ten bands together to create a one band raster file. I can do this in the raster calculator manually but cannot seem to find a way to do this using the raster calculator in the graphical modeller. There is a max of 5 bands that can be operated on at any one time. Any suggestions?
Grant Boxer
Perth, WA
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231003/ded0c8f3/attachment-0001.htm>
More information about the QGIS-User mailing list
