[Qgis-user] Unexpected change in pixel values during processing (Metashape/QGIS)
    Johannes Kröger (WhereGroup)
    johannes.kroeger at wheregroup.com
    Thu Oct  5 02:57:12 PDT 2023
Hi Dirk,
there is no such thing as "just exporting". What exactly do you do? What
does gdalinfo say about the original file and the exported file?
Cheers, Hannes
Am 05.10.23 um 10:10 schrieb Stulgies Dirk via QGIS-User:
> # Unexpected change in pixel values during processing (Metashape/QGIS)
> ## Software
> * QGIS 3.28
> * Agisoft Metashape 2.0.1
> ## Description
> I used Agisoft Metashape to create RGB GeoTiff. The source for this
> GeoTiff are images taken with a UAV (DJI M3M).
> When loading the GeoTiff into QGIS and processing the file, the pixel
> values for the same position differ between the original file and the
> process result.
> My first thought was that I somehow resampled, converted, or
> transformed the pixel values during the processing.
> So I simplified the process step by step to the bare minimum, but the
> result stayed the same.
> Even just exporting the file leads to changed pixel values.
> ## CRS not recognized
> Something I noticed while trying to solve this problem is that QGIS
> doesn't recognize the GeoTiffs CRS (EPSG:32632) as a predefined CRS
> but as a custom CRS. This is curious because I use a predefined CRS
> from Agisoft Metashape to create the GeoTiff.
> I tried to reproject the file and also to just change the CRS in the
> file's QGIS properties, but the pixel values still differ after
> processing the file.
> ### CRS defined in Agisoft Metashape:
> Projected Coordinate System: WGS 84 / UTM zone 32N (EPSG::32632)
> Linear Units: metre (EPSG::9001)
> Projection Method: Transverse Mercator
>     Latitude of natural origin: 0
>     Longitude of natural origin: 9
>     Scale factor at natural origin: 0.9996
>     False easting: 500000
>     False northing: 0
> Geographic Coordinate System: WGS 84 (EPSG::4326)
> Angular Units: degree (EPSG::9102)
> Geodetic Datum: World Geodetic System 1984 ensemble (EPSG::6326)
> Ellipsoid: WGS 84 (EPSG::7030)
> Prime Meridian: Greenwich (EPSG::8901)
> ### CRS regognized in QGIS:
> BOUNDCRS[
> SOURCECRS[
> PROJCRS[
> "WGS 84 / UTM zone 32N",
> BASEGEOGCRS[
> "WGS 84",
> DATUM[
> "World Geodetic System 1984",
> ELLIPSOID["WGS 84",6378137,298.257223563,LENGTHUNIT["metre",1]]
> PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433]],
> ID["EPSG",4326]
> CONVERSION[
> "UTM zone 32N",
> METHOD["Transverse Mercator",ID["EPSG",9807]],
> PARAMETER["Latitude of natural
> origin",0,ANGLEUNIT["degree",0.0174532925199433],ID["EPSG",8801]],
> PARAMETER["Longitude of natural
> origin",9,ANGLEUNIT["degree",0.0174532925199433],ID["EPSG",8802]],
> PARAMETER["Scale factor at natural
> origin",0.9996,SCALEUNIT["unity",1],ID["EPSG",8805]],
> PARAMETER["False easting",500000,LENGTHUNIT["metre",1],ID["EPSG",8806]],
> PARAMETER["False northing",0,LENGTHUNIT["metre",1],ID["EPSG",8807]]
> CS[Cartesian,2],
> AXIS["easting",east,ORDER[1],LENGTHUNIT["metre",1]],
> AXIS["northing",north,ORDER[2],LENGTHUNIT["metre",1]],
> ID["EPSG",32632]
> TARGETCRS[
> GEOGCRS[
> "WGS 84",
> DATUM[
> CS[ellipsoidal,2],
> AXIS["geodetic latitude
> (Lat)",north,ORDER[1],ANGLEUNIT["degree",0.0174532925199433]],
> AXIS["geodetic longitude
> (Lon)",east,ORDER[2],ANGLEUNIT["degree",0.0174532925199433]],
> ID["EPSG",4326]
> ABRIDGEDTRANSFORMATION[
> "Transformation from WGS 84 to WGS84",
> METHOD["Position Vector transformation (geog2D domain)",ID["EPSG",9606]],
> PARAMETER["X-axis translation",0,ID["EPSG",8605]],
> PARAMETER["Y-axis translation",0,ID["EPSG",8606]],
> PARAMETER["Z-axis translation",0,ID["EPSG",8607]],
> PARAMETER["X-axis rotation",0,ID["EPSG",8608]],
> PARAMETER["Y-axis rotation",0,ID["EPSG",8609]],
> PARAMETER["Z-axis rotation",0,ID["EPSG",8610]],
> PARAMETER["Scale difference",1,ID["EPSG",8611]]
> ## Question
> The questions I have are:
> 1. What could be the reason for this behavior?
> 2. How do I prevent the pixel values from changing?
> Kind regards,
> i.A. Dirk Stulgies
> NPZ Innovation GmbH
> Hohenlieth-Hof, D-24363 Holtsee
> Tel.+49-4351-736 277 <tel:%2B49-4351-736%20277>__
> Fax +49-4351-736 271 <tel:%2B49-4351-736%20271>
> Mail:d.stulgies at npz-innovation.de__
> Web:www.npz-innovation.de <http://www.npz-innovation.de/>
> Firmensitz Hohenlieth, Holtsee
> Amtsgericht Kiel, HRB 15342 Kl
> Geschäftsführer: Dr. Gunhild Leckband, Thorsten Pommer
> This email was scanned by Bitdefender
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Johannes Kröger / GIS-Entwickler/-Berater
Aufwind durch Wissen!
Web-Seminare und Online-Schulungen
bei derwww.foss-academy.com
WhereGroup GmbH
c/o KK03 GmbH
Lange Reihe 29
20099 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231005/964775f8/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231005/964775f8/attachment-0001.png>
More information about the QGIS-User
