[Qgis-user] setting graduated symbology for a small postgres point table crashing qgis.
Andreas Neumann andreas at qgis.org
Wed Oct 11 01:58:56 PDT 2023
Hi Damien,
Can you submit a bug report please?
NULL values in the data shouldn't make QGIS freeze.
Thanks,
Andreas
On Wed, 11 Oct 2023 at 10:51, damien stephens via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> never mind I figured it out.
> the graduated engine does not like null values in the field, so i used a
> calulated field:
> case when field is null then .001 else field end
> On Wed, Oct 11, 2023 at 4:41 PM damien stephens <damien.stephens at gmail.com>
> wrote:
>> Hi All.
>> I have a point table view with around 50,000 records and 160 fields in
>> postgres  which loads into qgis very quickly.
>> the problem comes when i try to assign a graduated symbology.
>> no matter which Mode i use - fixed interval, jenks etc, when i hit the
>> classify button qgis freezes  - and had been frozen for around an hour.
>> this has happened with 2 different views.
>> anyone else seen this / have a fix.
>> It could be a stupid mistake on my part as i am new to using Post gres,
>> as trialling  it vs the current mssql setup.
>> thanks in advance
>> Damien
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Andreas Neumann
QGIS.ORG board member (treasurer)
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231011/59f3fe40/attachment.htm>
More information about the QGIS-User mailing list
