[Qgis-user] QGIS-User Digest, Vol 212, Issue 36
Tim Fearn mountainprana.map.works at gmail.com
Fri Oct 27 08:41:54 PDT 2023
Thanks Alexei,
  Disabling layer masks and using a small buffer is also the only work around that I have found. Really hoping for some “award winning” solution here. The buffering works and allows the print export as you said, but isn’t as professional a finish as what I’m hoping for.  I really appreciate the reinforcement that this is more of a bug than my hardware, and will continue to look for something more seamless.
Cheers,
Tim Fearn
> Hi Tim,
> I believe your issue might be related to this bug:
> https://github.com/qgis/QGIS/issues/50526
> Which from GitHub looks like it has not yet been addressed.
> Or since you didn't say if you're using blend modes, it might be that there are multiple issues related to masking.
> My only workaround was to disable label masks and use semi transparent buffers on labels instead. Not as nice an effect but at least the export will work.
> Alexei
>> On October 26, 2023 5:58:10 PM GMT+01:00, Tim Fearn
>> Hello all,
>> In trying to export a print layout which contains a contour layer where index elevation labels are using a masked symbology, Qgis crashes. After doing some research around the internet I see that this has at least in the pass been a known bug.            I?m wondering if anyone knows of a workaround or if it has been fixed and the issue persists due to my older operating system?  I have tried the export throughout several releases  Firenze 3.28 as well as Lima 3.32 running Mac OS High Sierra 10.13.6
>> Thank you everyone!
>> Tim Fearn
>> Cheers,
>> Tim Fearn
>> Sent from my iPhone
More information about the QGIS-User mailing list
