[Qgis-user] Output to pdf file doesn't contain vector details
Michael McNeil memcneil02 at gmail.com
Mon Sep 18 08:43:08 PDT 2023
Chris, Garth, others,
Now that we've resolved the issue of reentering Qgis and accessing my
previously saved project data (thanks again, Garth!), I can go on to
investigate whether Qgis can serve as my entire graphics toolkit for
working on and producing the final output version of maps. I certainly
wouldn't mind that being the case (even though powerful vector-graphics
tools such as CorelDraw also have their place, I maintain).
*Shapefiles*
But, it should also be possible to use Qgis to (say) input GIS data files
in one format (such as NASA's SRTM “tiles”), then output the data in
another vector-graphics format (such as .shp shapefiles or .svg files) –
for directing the data to another application for further processing, as
convenient – whether or not Qgis technically can do much the same further
processing.
In this regard, I generated shapefiles corresponding to the input SRTM
data, but I encountered 2 problems there: First, my preferred secondary
application CorelDraw does not accept .shp (and associated files) input –
though it does read .svg and .pdf files.
Second, to get past this initial limitation, I attempted to input Qgis'
output shapefiles to the website Aspose's page for converting shapefiles
into svg files only to have it declare allQgis' shapefiles to be “invalid
data.” I have a trouble report in with them about that.
I would prefer to use shapefiles to transfer the data – that is intended to
be an interim format – however CorelDraw doesn't accept shapefiles (.shp) ,
but it does svg
On Wed, Sep 13, 2023 at 12:18 PM chris hermansen <clhermansen at gmail.com>
wrote:
> Michael and list.
> On Wed, Sep 13, 2023 at 10:22 AM Michael Edward McNeil <
> memcneil02 at gmail.com> wrote:
>> Chris, I could experiment with QGIS's cartography capabilities more if I
>> could save my project, exit, and then resume working on it later. My other
>> problem with QGIS interferes with that potential procedure.
> Perhaps there is a degree of misunderstanding here.
> When you work with say Microsoft Word to eventually produce a document
> that you will export to PDF to send to others, you don't save your interim
> work in PDF; you save it in Word's internal format, .docx.
> Similarly with QGIS, you save an ongoing piece of work as a project. Look
> at the Project menu item, where you will see the ability to Save or Save
> As.  When you're ready to export your work to PDF or some other output
> format, there is an "export work flow".
> There is also an important QGIS component not immediately visible, which
> is the Print Layout, also available in the Project menu item.
> You might wish to follow through the online documentation here
> https://docs.qgis.org/3.28/en/docs/training_manual/map_composer/map_composer.html
> to see how that component is used to make a map, with surround, annotation,
> etc ready for export to PDF as a finished product.
> So the overall workflow is to assemble the various layers you wish to
> depict on the main QGIS screen, applying symbology to each layer; then open
> a print layout to wrap up what's on screen into a full map composition.
>> Yes, aligning a single layer in another app with its true position is a
>> problem. If I continue trying to do it this way, I'd probably also output
>> meridians and possibly other clues (e.g., the British coastline) to allow
>> aligning it properly.
> Don't forget that you can add useful raster layers, like Open Street Map,
> to your screen and map composition, to save yourself a lot of time with
> respect to tracking down vector or raster data sets, symbolizing them, and
> so forth.
> Chris Hermansen · clhermansen "at" gmail "dot" com
> C'est ma façon de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230918/9c931296/attachment.htm>
More information about the QGIS-User mailing list
