[Qgis-user] The Google maps satellite layer for my project background only appears on half of the page
rabmailbox-forums at yahoo.com rabmailbox-forums at yahoo.com
Tue Sep 19 17:44:42 PDT 2023
I have a QGIS problem with Google satellite images only appearing over half of the screen, see attached .jpg.   I am currently on version 3.28.11, BUT I have had this problem for quite awhile and with several other versions, 3.6.1.1, 3.8.1.1, 3.10.13.2 & 3.16.8.
I have updated through several versions, always with the same problem, so it doesn't seem verison related. I kept hoping a new version would fix it, but it has not helped.
When I move the background map around using my mouse, the whole satellite image briefly appears on the entire background, but when I let go of the mouse button and the map "settles", half of the image disappears.  It is always the right half of the screen that shows the satellite image and the left half that is white/blank, see attached .jpg.  If I move the map the formerly "blank" or "white" part of the satellite image will appear, but once I let go of the mouse, still only half of the screen (right half) will show the satellite image.
I assume something is blocking the satellite image, but if I start a new blank project the problem is still there, so it does not appear to be a layer in a current project
Admittedly, I am not very good with QGIS, so this may be a simple problem.
Can anyone help?
Thanks,
Rick
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230920/2de087e2/attachment.htm>
More information about the QGIS-User mailing list
