[Qgis-user] [EXTERNAL] AW: GDAL libraries in standalone installer for Windows
Frank Broniewski
broniewski at a-a.lu
Thu Sep 28 05:28:51 PDT 2023
The gdalinfo binary has a –build flag
C:\OSGeo4W\bin>gdalinfo.exe --build
PAM_ENABLED=YES
OGR_ENABLED=YES
CURL_ENABLED=YES
CURL_VERSION=8.1.2
GEOS_ENABLED=YES
GEOS_VERSION=3.12.0-CAPI-1.18.0
PROJ_BUILD_VERSION=9.2.1
PROJ_RUNTIME_VERSION=9.2.1
COMPILER=MSVC 192930143
You should be able to find this in your QGIS installation as well somewhere … but otherwise, I am not sure I can help you furthermore here
Best,
Frank
Von: QGIS-User <qgis-user-bounces at lists.osgeo.org> Im Auftrag von Newcomb, Doug via QGIS-User
Gesendet: Donnerstag, 28. September 2023 14:17
An: qgis-user at lists.osgeo.org
Betreff: [Qgis-user] Fw: [EXTERNAL] AW: GDAL libraries in standalone installer for Windows
Sorry, I forgot to copy the list.
From: Newcomb, Doug <doug_newcomb at fws.gov<mailto:doug_newcomb at fws.gov>>
Sent: Thursday, September 28, 2023 7:44 AM
To: Frank Broniewski <broniewski at a-a.lu<mailto:broniewski at a-a.lu>>
Subject: Re: [EXTERNAL] AW: GDAL libraries in standalone installer for Windows
Thanks for reaching out Frank!
That covers GDAL, but not the components that GDAL was compiled with. I did find out from another source that you can use the setup utility in the Standalone installer to determine the current library version, but that is not quite what I was hoping for.
Doug
From: Frank Broniewski <broniewski at a-a.lu<mailto:broniewski at a-a.lu>>
Sent: Thursday, September 28, 2023 1:17 AM
To: Newcomb, Doug <doug_newcomb at fws.gov<mailto:doug_newcomb at fws.gov>>; qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org> <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>>
Subject: [EXTERNAL] AW: GDAL libraries in standalone installer for Windows
This email has been received from outside of DOI - Use caution before clicking on links, opening attachments, or responding.
Hi Doug,
if you go to Help -> About you get a list of libraries and their respective versions.
HTH
Frank
Von: QGIS-User <qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>> Im Auftrag von Newcomb, Doug via QGIS-User
Gesendet: Mittwoch, 27. September 2023 22:31
An: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Betreff: [Qgis-user] GDAL libraries in standalone installer for Windows
Hi Folks,
Is there a way that I can easily find out the versions of the libraries compiled into the QGIS Standalone installer for Windows?
Doug
Doug Newcomb - Cartographer
USFWS
551F Pylon Dr
Raleigh, NC
New Number (984) 308-0861 doug_newcomb at fws.gov<mailto:doug_newcomb at fws.gov>
NOTE: This email correspondence and any attachments to and from this sender is subject to the Freedom of Information Act (FOIA) and may be disclosed to third parties.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230928/8a6f5e34/attachment.htm>
More information about the QGIS-User
