[Qgis-user] STEPS TO BUILD FROM SOURCE QGIS DESKTOP INCLUDING ORACLE LIBRARIES
Jürgen E. Fischer jef at norbit.de
Fri Sep 29 07:03:45 PDT 2023
Hi Richard,
On Fri, 29. Sep 2023 at 14:39:01 +0200, Richard Duivenvoorde via QGIS-User wrote:
> Ubercool! These lines even work on my current Debian Bookworm \o/
Although I'd change the dch line to bookworm-oracle in that case.
> One question: the result is:
> qgis-build-deps_3.32.3~sid~oracle1_all.deb
> but where does it install after
> sudo dpkg -i qgis-build-deps_3.32.3~sid~oracle1_all.deb
> or
> sudo gdebi qgis-build-deps_3.32.3~sid~oracle1_all.deb
> I could not find it in /usr/bin. I can only find it in the
> qgis-3.32.3~sid~oracle1/debian/build/output/bin/qgis
> or
> qgis-3.32.3~sid~oracle1/debian/qgis/usr/bin/qgis
> should it not be installed on the user's disk?
Sure, because that is the actual result (or the main part of it).
qgis-build-deps is just an empty package from mk-build-deps that depends on all
packages which qgis needs to build.   So it installing what apt-get build-dep
would, just for the dependencies of the current source (listed in
debian/control) and not the package in the repository.
> PS: I think this deserves a place in the (linux specific) docs ( while it is
> working :-) )...
ack. ;)
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230929/d7b50761/attachment.sig>
More information about the QGIS-User mailing list
