[Qgis-user] Convert .shp to CAD, with attribute values as different layers
DelazJ delazj at gmail.com
Tue Feb 13 03:11:36 PST 2024
Hi Chaz,
There was a bug that hid that in the past (fixed in next release) but if you scroll the dxf dialog to the right, you'll get an "output layer attribute" column that helps you select whether a layer should remain a layer in the dxf or split across one of its fields.
https://docs.qgis.org/3.28/en/docs/user_manual/managing_data_source/create_layers.html/create-dxf-files
Regards,
Harrissou
Le 13 février 2024 11:21:13 GMT+01:00, Christine via QGIS-User <qgis-user at lists.osgeo.org> a écrit :
>_______________________________________________
>QGIS-User mailing list
>QGIS-User at lists.osgeo.org
>List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240213/bf2fb7a9/attachment-0001.htm>
More information about the QGIS-User mailing list
