[Qgis-user] Issue with Building Virtual Point Cloud (VPC)
Mike Treglia mtreglia at gmail.com
Tue Feb 13 10:03:48 PST 2024
Hi all,
I have a folder with a LOT of point cloud files (1,740) - all stored as
cloud optimized point clouds (COPCs), which were converted from .las files
via QGIS. I'm trying to build a virtual point cloud via QGIS, selecting the
folder with all of the COPCs. However as its running, fairly on, it stops
running and I get a message "incorrect parameter value for layers."
I'm not finding any log files, and no .vpc file is created.
Any suggestions for troubleshooting and such? They are all from the same
source, for the same general geographic area, so while I haven't checked
all of the CRS information is the same, anticipate it should be across all
of these files.
And in case it helps, below is the "About" info for my install
Best,
Mike
QGIS version
3.34.3-Prizren
QGIS code revision
47373234ac <https://github.com/qgis/QGIS/commit/47373234ac>
Qt version
5.15.3
Python version
3.9.18
GDAL/OGR version
3.8.3
PROJ version
9.3.1
EPSG Registry database version
v10.098 (2023-11-24)
GEOS version
3.12.1-CAPI-1.18.1
SQLite version
3.41.1
PDAL version
2.6.0
PostgreSQL client version
15.2
SpatiaLite version
5.1.0
QWT version
6.1.6
QScintilla2 version
2.13.4
OS version
Windows 10 Version 2009
Active Python plugins
BivariateRenderer
1.0.1
DataPlotly
3.9
PeliasGeocoding
0.1
pg_metadata
1.2.2
postgis_geoprocessing
0.9
qgis2web
3.16.0
quick_map_services
0.19.29
Socrata
2.2
valuetool
3.0.15
db_manager
0.1.20
MetaSearch
0.3.6
processing
2.12.99
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240213/206966c5/attachment.htm>
More information about the QGIS-User mailing list
