[Qgis-user] QGIS and Mango
chris hermansen clhermansen at gmail.com
Thu Feb 22 10:02:56 PST 2024
Collin and list,
On Thu, Feb 22, 2024 at 7:43 AM Collin Coe via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hey All,
> Let me know if this is the appropriate place to send a question like this,
> or if there is a better support channel I might be able to reach out to.
> So I, internal IT, have been tasked with assisting our GIS department with
> standing up a WMS server to serve local mapping data to MangoMaps. This is
> all in an effort to distance ourselves from ESRI as they want big money to
> store the volume of GIS data we have on their hosted solution.
> I have stood up the QGIS server on a Windows 2019 server we are running
> here, gotten our GIS director connected to it using QGIS desktop, and he
> has even published a project that we can open just fine using the FQDN of
> our QGIS server externally. But here is the catch, while he can load the
> WMS data just fine in ARCGIS Pro on his home desktop, whenever we attempt
> to plug the string into MangoMaps as a WMS data source we get a 403 error
> and a 500 error on the Mango side and it fails to pull in the data.
> My question is this, does anyone here have the same setup we do, pumping
> WMS data from QGIS server over https to MangoMaps, and would you be able to
> give some advice on how you were able to get that working? We are working
> with Mango support, but this falls a bit out of their wheelhouse, as it
> seems like our Apache QGIS server is the one giving the 403 error. The bit
> that confuses me, is that it is working just fine in ARCGIS traversing the
> same network, from the same host. This leads me to believe that Mango needs
> something special/different done on their end to make it work.
> I will also be the first to note that I am not an Apache/GIS expert, and
> it very well could be an error we have made in our servers configuration.
> We have gone over the configuration with Mango, and they do not see any
> errors, but again, that is not their wheelhouse.
A 403 error usually indicates something along the lines that the web client
is trying to access something for which it doesn't have permission.  For
example Mozilla docs state:
403 Forbidden
> The HTTP 403 Forbidden response status code indicates that the server
> understands the request but refuses to authorize it.
> This status is similar to 401, but for the 403 Forbidden status code,
> re-authenticating makes no difference. The access is tied to the
> application logic, such as insufficient rights to a resource.
Note "the server understands the request but refuses to authorize it".
Looking at your URL, it appears your request doesn't go directly to the
QGIS server, but rather goes to mangomap.com (it is "mangomap" and not
"mangomaps", correct?).
Is your qgis server / apache server / network policy set up to accept
requests from outside your network?
The text "(anonymous)" appears in the log following.  Could this mean that
mangomap.com is trying to access your qgis server as user "anonymous"?
When you configure MangoMap(s) to talk to your qgis server, have you
entered the necessary credentials (user name and password)?
Can you verify that your qgis server is ok to respond to the
"getcapabilities" request with the parameters supplied?  Ie maybe try it
with curl from inside your network?
> At any rate, see the error that we get in Mango below, and let me know if
> you have any advice.
> application_one_page_app-e0c184742f67970dfcbc711490e8927caf4b7d25f000dd69df5a805edeca457b.js:63
> GET
> https://mangomap.com/clients/5dfb3952-42b1-11ee-83b6-027d7e0bb32b/coverage_stores/get_wms_layers?wms_source=https%253A%252F%252Fwms.vanburencountymi.gov%252Fcgi-bin%252Fqgis_mapserv.fcgi.exe%253Fservice%253DWMS%2526request%253DGetCapabilities%2526version%253D1.3.0&_=1708610138093
> 403 (Forbidden)
> send @
> ajax @
> request @
> application_one_page_app-e0c184742f67970dfcbc711490e8927caf4b7d25f000dd69df5a805edeca457b.js:640
> connectWms @
> application_data_portal-f8ccb478ddb794401762bdd65a58df88cca0a03a304324c540f5d9b97c5622bd.js:11
> (anonymous) @
> application_data_portal-f8ccb478ddb794401762bdd65a58df88cca0a03a304324c540f5d9b97c5622bd.js:13
> dispatch @
> application_one_page_app-e0c184742f67970dfcbc711490e8927caf4b7d25f000dd69df5a805edeca457b.js:62
> v.handle @
> application_one_page_app-e0c184742f67970dfcbc711490e8927caf4b7d25f000dd69df5a805edeca457b.js:61
>   [image: Facebook] <https://www.facebook.com/VanBurenCountyMI/>    [image:
> LinkedIn] <https://www.linkedin.com/company/van-buren-county-government>
>  [image: Twitter] <https://twitter.com/VanBurenCoMI>
> *Collin Coe*
> *IT Operations Manager*
> *Van Buren County Information Services*
> a:
> 219 E. Paw Paw St, Suite 202
> Paw Paw, MI 49079
> t:
> 269-657-8266 ext. 1248
> f:
> 269-657-8297
> w:
> https://www.vanburencountymi.gov  e: coec at vanburencountymi.gov
> Need to meet with me? Book a meeting or check my availability with this
> link: Microsoft Bookings
> <https://outlook.office365.com/owa/calendar/CollinCoePersonalBookings@VanBurenCo.onmicrosoft.com/bookings/>
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Chris Hermansen · clhermansen "at" gmail "dot" com
C'est ma façon de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240222/5df43b9e/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240222/5df43b9e/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240222/5df43b9e/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240222/5df43b9e/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240222/5df43b9e/attachment-0007.png>
More information about the QGIS-User mailing list
