[Qgis-user] QGIS and Mango
chris hermansen clhermansen at gmail.com
Thu Feb 22 11:42:24 PST 2024
Collin and list,
On Thu, Feb 22, 2024 at 10:19 AM Collin Coe <CoeC at vanburencountymi.gov>
wrote:
> Thank you for your response, see my answers below.
>    - Note "the server understands the request but refuses to authorize
>    it".
>    - That was my thought, as if I shut the Apache service down, the
>       request times out instead.
>       - Looking at your URL, it appears your request doesn't go directly
>    to the QGIS server, but rather goes to mangomap.com
>    <https://urldefense.com/v3/__http://mangomap.com__;!!PO4-HVKE-L9l8-c!hPRhCbuNMimPUluNMhaOjOJgXVTDfVBj1JPev1G7lPbcxJRAJ-TJ3tF3MBfmcrEf2zi3lwhtSo22EFtbSFQ2WPE90Tv8$> (it
>    is "mangomap" and not "mangomaps", correct?).
>    - The URL that we program into Mango is below, the one from the error
>       is what I assume is Mango reformatting the URL behind the scenes as it
>       presents in their UI to me. Note this URL is something that Mango advised
>       us to use for the call on our server. We have tried it with the one
>       specified in the below question as well to the same results.
>          https://wms.vanburencountymi.gov/cgi-bin/qgis_mapserv.fcgi.exe?service=WMS&request=GetCapabilities&version=1.3.0
If I try to access this URL with curl I get an error, I suppose because no
parameters are specified:
 $ curl '
<ServerException>Layer(s) not valid</ServerException>
>          - Is your qgis server / apache server / network policy set up to
>    accept requests from outside your network?
>    - It is. We have tested with ARCGIS and it is able to pull in the WMS
>       data fine with the below URL
>          https://wms.vanburencountymi.gov/cgi-bin/qgis_mapserv.fcgi.exe?service=WMS&request=GetCapabilities&version=1.3.0&crs=EPSG:3857&map=VBCWMS1.qgz&layers=APTEST
If I try to access this URL with curl I get stuff:
$ curl '
<?xml version="1.0" encoding="utf-8"?>
<WMS_Capabilities version="1.3.0" xsi:schemaLocation="
http://www.opengis.net/wms
http://schemas.opengis.net/wms/1.3.0/capabilities_1_3_0.xsd
http://www.opengis.net/sld
http://schemas.opengis.net/sld/1.1.0/sld_capabilities.xsd
http://www.qgis.org/wms
https://wms.vanburencountymi.gov/cgi-bin/qgis_mapserv.fcgi.exe?MAP=VBCWMS1.qgz&SERVICE=WMS&REQUEST=GetSchemaExtension"
xmlns:sld="http://www.opengis.net/sld" xmlns:qgs="http://www.qgis.org/wms"
xmlns="http://www.opengis.net/wms" xmlns:xsi="
http://www.w3.org/2001/XMLSchema-instance">
 <Service>
  <Name>WMS</Name>
  <Title>VBCWMS1</Title>
  <KeywordList>
   <Keyword vocabulary="ISO">infoMapAccessService</Keyword>
  </KeywordList>
  <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
xlink:type="simple" xlink:href="
  <Fees>conditions unknown</Fees>
  <AccessConstraints>None</AccessConstraints>
 </Service>
 <Capability>
  <Request>
   <GetCapabilities>
    <Format>text/xml</Format>
    <DCPType>
     <HTTP>
      <Get>
https://wms.vanburencountymi.gov/cgi-bin/qgis_mapserv.fcgi.exe?MAP=VBCWMS1.qgz&amp
      </Get>
     </HTTP>
    </DCPType>
   </GetCapabilities>
 </Capability>
</WMS_Capabilities>
If I try the original you sent to me with curl, I get:
$ curl '
https://mangomap.com/clients/5dfb3952-42b1-11ee-83b6-027d7e0bb32b/coverage_stores/get_wms_layers?wms_source=https%253A%252F%252Fwms.vanburencountymi.gov%252Fcgi-bin%252Fqgis_mapserv.fcgi.exe%253Fservice%253DWMS%2526request%253DGetCapabilities%2526version%253D1.3.0&_=1708610138093
<html><body>You are being <a href="https://mangomap.com/sign-in
">redirected</a>.</body></html>$
which lets me know mangomap.com is doing a redirect as we suspected.  If I
try with the curl "follow redirects" switch I am sent to mangomap.com's
login page:
 $ curl -L '
<!DOCTYPE html>
<html>
<head>
<title>Sign in to Mango</title>
</html>
So, so far so good, but not talking to your qgis server yet.
You might find it worthwhile continuing this way with curl, supplying your
login credentials, so you can get a bit more information on what's going on.
>          - The text "(anonymous)" appears in the log following.  Could
>    this mean that mangomap.com
>    <https://urldefense.com/v3/__http://mangomap.com__;!!PO4-HVKE-L9l8-c!hPRhCbuNMimPUluNMhaOjOJgXVTDfVBj1JPev1G7lPbcxJRAJ-TJ3tF3MBfmcrEf2zi3lwhtSo22EFtbSFQ2WPE90Tv8$> is
>    trying to access your qgis server as user "anonymous"?
>    - It is trying to access it anonymously, but I will note that ARCGIS
>       also accesses it this way and works fine
>       - When you configure MangoMap(s) to talk to your qgis server, have
>    you entered the necessary credentials (user name and password)?
>    - See above, it is availible anonymously. We will be locking it down
>       with creds eventually, but for testing it is
Got it.
>       - Can you verify that your qgis server is ok to respond to the
>    "getcapabilities" request with the parameters supplied?  Ie maybe try it
>    with curl from inside your network?
>    - This is one spot that I am thinking I am missing. I do have the
>       allowed access type of GET allowed, in fact for testing we have all access
>       types allowed at the moment, but I am not sure that we have set that up
>       properly. Below is a screencap of that part of my Apache config file. I
>       shared that with the Mango folks, and they seen to think it looks good.
We've verified above that your Apache / QGIS configuration is correct using
curl to access the URL you provided.  So I don't think you need to tweak
things in Apache.
I've pulled the redirect URL out of the mangomap.com URL you provided in
your first email; it looks like this:
https://wms.vanburencountymi.gov/cgi-bin/qgis_mapserv.fcgi.exe?service=WMS&request=GetCapabilities&version=1.3.0&_=1708610138093
When I try a curl with that, I get a "Layer(s) not valid" exception
returned:
$ curl '
So it looks to me like MangoMaps is mangling your calls to
getCapabilities.  In particular MangoMaps is not supplying the parameters:
crs=EPSG:3857
map=VBCWMS1.qgz
layers=APTEST
that your working test call supplied, while it is supplying
version=1.3.0
_=1708610138093
Not sure what that "_" parameter is.  Maybe map extent or map centre or
something like that, in some kind of fixed format?
So something needs to be adjusted in the MangoMaps config so that it sends
the crs, the map and the layers required.
Chris Hermansen · clhermansen "at" gmail "dot" com
C'est ma façon de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240222/4e9b3a1d/attachment.htm>
More information about the QGIS-User mailing list
