[Qgis-user] Help with building from source
Adam Nielsen a.nielsen at shikadi.net
Thu Feb 22 19:46:01 PST 2024
> All works well until part way through, when I get an error:
> [ 63%] Built target provider_postgres_a
> [ 63%] Built target qgis_gui_autogen
> make: *** [Makefile:166: all] Error 2
> I can't see a log file anywhere.
It looks like it's a parallel build and the error happened earlier so
it's not visible in your output.  You can try disabling the parallel
build (used to be "make -j1" but I forget if that works here) which
should at least make the errors appear at the end of the output so you
can more easily locate them.
Cheers,
Adam.
More information about the QGIS-User mailing list
