[Qgis-user] Cannot open up projects in 3.36.0
Don Harter harterc2 at att.net
Thu Feb 29 12:06:09 PST 2024
This is similar to a problem that I have after trying to build QGIS.  I
checked my ccmake options and the build log.
The only possible problem is that my version of numpy is not in the
range of what is wanted.
On 2/29/24 2:56 PM, Christian Castro via QGIS-User wrote:
> Hello,
> I installed QGIS 3.36.0 and I have some strange behavior.
> I see my projects in the middle window named "Recent Projects", and I see a screenshot of the project, but when I double-click on it to open it, nothing happens.
> This was a project that started off at 3.24.1 and opened in 3.36.0 and saved in 3.36.0, but when I close QGIS 3.36.0 and double-click on my project file from windows, nothing happens.
> The new QGIS 3.3.6.0 program does open, and I see the project preview in the middle pane named "Recent Projects". But, when I double-click on the name of the project, nothing happens, I don't see the window showing me the project stuff.
> This is unlike the 3.24.1 version where when I double-clicked on a project file, it would show me the project stuff.
> This is happening in both brand new projects created in 3.36.0 and old projects created in version 3.24.1 and saved in 3.36.0 (to convert it to the 3.3.6.0 format).
> Maybe there's some kind of View pane that needs to be enabled under the View menu?
> If so can someone please let me know.
> The Pan Map option under the View menu is enabled and Show Map Tips under the View menu is also enabled.
> Thanks,
> Christian
> ****WARNING**** This email message (including any attachments) are to be treated as confidential/proprietary and may contain copyrighted or other legally protected information. It is intended only for the addressee(s) identified above. If you are not the addressee(s), or an employee or agent of the addressee(s), please note that any dissemination, distribution, or copying of this communication is strictly prohibited. If you have received this information in error, please destroy the information and notify the sender of the error. Thank you.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240229/f107160b/attachment.htm>
More information about the QGIS-User mailing list
