[Qgis-user] Atlas printing to PDF
Springfield Harrison stellargps at gmail.com
Thu Feb 29 23:57:26 PST 2024
Hello Nigel,
Okay, thanks very much, just on the verge of updating now.
Your tip about using a copy of the project file is a good one. Will
certainly do that.
I hope the update will fix the Atlas printing problem but I'm not
holding my breath.  It contains several large map raster files which may
be the problem.
Thanks again…
Cheers, Spring
On 2024-02-29 22:26, Nigel Berjak wrote:
> Hi Spring
> It may be worthwhile trying this. Even 3.26 final release, as an
> interim version. Also, ensure you do not open the original project
> file, but rather a copy, in case you save it and cannot return
> (possibly) to using it with the older version.
> Regards,
> Nigel Berjak
> Please consider the environment before printing this email.
> On 2024-03-01 05:16, Springfield Harrison wrote:
>> OK, thank you.  I'm using 3.16.4, perhaps I should move up to 3.32.3?
>> Cheers, Spring
>> On 2024-02-29 05:15, Nigel Berjak wrote:
>>> Hi
>>> I have had to revert to using an older version (3.32.3) for one of
>>> my projects, where the Atlas sheets bombs the application (3.34.3).
>>> Is this the issue you are having?
>>> Regards,
>>> Nigel Berjak
>>> On 2024-02-29 13:28, Springfield Harrison via QGIS-User wrote:
>>>> Hello,
>>>> Printing a PDF Atlas is a total fail - 1 page if I'm lucky, mostly
>>>> 1 blank page.  Is there a work around?
>>>> Thanks very much.  I'm sorry if this has been already covered,
>>>> there seems to be no searchable forum.
>>>> Cheers, Spring Harrison
>>>> _______________________________________________
>>>> QGIS-User mailing list
>>>> QGIS-User at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
More information about the QGIS-User mailing list
