[Qgis-user] Help - Fix Geometries Required GEOS 3.10
Andrea Giudiceandrea andreaerdna at libero.it
Fri Jan 12 17:10:37 PST 2024
> Mars Sjoden marsofearth at gmail.com
> Fri Jan 12 11:53:20 PST 2024
> QGIS version: 3.28.14-Firenze
> GEOS version: 3.9.1-CAPI-1.14.2
> *Algorithm 'Fix geometries' starting…*
> The structured method to make geometries valid requires a QGIS build based
> on GEOS 3.10 or later
Hi Mars Sjoden,
as explained in the "Fix geometries" processing algorithm's help page
[1], a QGIS version built with the GEOS library version 3.10 or later is
required in order to use the "Structure" repair method.
Since your QGIS build uses a GEOS 3.9 version, you can obviously only
use the "Linework" repair method. So you need to select the "Linework"
method for the "Repair method" parameter in the processing algorithm
dialog window.
Alternatively, you can install and use a QGIS version build with a more
recent GEOS version as instructed in the Download page of the QGIS
website [2][3].
This way you can use both the "Linework" and the "Structure" repair
methods with the "Fix geometries" processing algorithm.
Best regards.
Andrea
[1]
https://docs.qgis.org/3.28/en/docs/user_manual/processing_algs/qgis/vectorgeometry.html#fix-geometries
[2] https://qgis.org/en/site/forusers/download.html#mac
[3] https://qgis.org/en/site/forusers/alldownloads.html#macports
More information about the QGIS-User mailing list
