[Qgis-user] Use of "description column" in "value relation widget"
Karl Magnus Jönsson Karl-Magnus.Jonsson at kristianstad.se
Wed Jan 17 04:40:15 PST 2024
Hi!
As I know it you get the description when you hover the different options in the dropdown. It would sometimes have been nice to have the description visible to the user in the dropdown and the value (not visible) stored in the attribute.
Kind regards
Karl-Magnus Jönsson
-----Ursprungligt meddelande-----
Från: QGIS-User <qgis-user-bounces at lists.osgeo.org> För Klaus Mithöfer via QGIS-User
Skickat: den 16 januari 2024 12:32
Till: qgis-user at lists.osgeo.org
Ämne: [Qgis-user] Use of "description column" in "value relation widget"
Dear all,
I'd like to use the "description column" in "value relation widget". I thought I could create an expression fro the drop-down list like concat("field1","field2"). But it doesn't work. What ist the "description column" good for?
Kind regards
Klaus
QGIS-User mailing list
QGIS-User at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
More information about the QGIS-User mailing list
