[Qgis-user] building gdal for mrsid
Don Harter harterc2 at att.net
Sun Jan 21 07:08:10 PST 2024
OK. Thanks. Those scripts don't use .deb packages so nothing would be
registered with dpkg.  I have had problems before with unregistered
packages lying around.  I just fixed such an issue with GCC.  I don't
even see a package that is available for libecwj2. In what  directory is
the build script run in?  I already have gdal installed. Will it
overwrite the existing ubuntu locations for the gdal packages? If I were
to purge those packages then other packages that rely on them would have
unfulfilled dependencies. I see that script is for an earlier version of
ubuntu.  I am running :  Ubuntu 22.04.3 LTS. And my gcc (gcc (GCC)
12.3.1 20230626) is newer so I have  downloaded  the other/newer mrsid
file.
So if I download the source for the .deb packages and replace the
scripts in them with those 2 that you located for me, will that work?
On 1/21/24 8:51 AM, Even Rouault wrote:
> Hi,
> cf
> https://github.com/OSGeo/gdal/blob/master/.github/workflows/ubuntu_20.04/Dockerfile.ci#L144
> and
> https://github.com/OSGeo/gdal/blob/master/.github/workflows/ubuntu_20.04/build.sh#L15
> for a build recipee to build GDAL >= 3.5 with MrSID support
> Even
> Le 21/01/2024 à 03:10, Don Harter via QGIS-User a écrit :
>> I have been following this procedure to build gdal with mrsid
>> capabilities.  I had done this a while back previously but the
>> different dependencies between packages cause a mess.
>> https://trac.osgeo.org/ubuntugis/wiki/TutorialMrSid
>> I tried to run this command:
>> sudo apt-get install libgdal-mrsid-src
>> But that package is not available in the unbuntugis repository.
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240121/5792baec/attachment.htm>
More information about the QGIS-User mailing list
