[Qgis-user] Hillshade default direction
Raymond Nijssen r.nijssen at terglobo.nl
Mon Jan 22 23:38:03 PST 2024
Hi David,
On 23-01-2024 06:39, David Strip via QGIS-User wrote:
> After a lifetime of NW hillshades, my eye reverses hills and valleys
> when I shift the sun.
This is not caused by looking at NW hillshades, but by looking at real
life objects where light normally comes from above. This is what your
brain is expecting and therefore it generates a 3D "bump map" for you
that way.
And that's why a GIS uses a sun position from the top of the map, often
north.
(Turning your SW map upside down should fix the problem.)
Raymond
More information about the QGIS-User mailing list
