[Qgis-user] Plugin available on repo but not in QGIS
Richard Duivenvoorde rdmailings at duif.net
Thu Jan 25 05:13:31 PST 2024
It is approved, so should be in plugins.xml
BUT(!) as it is experimental, you only see it when you have the 'Show  also Experimental Plugins' checkbox checked in the repo settings.
You probably have, but it is default UNchecked.
Regards,
On 1/25/24 12:12, Jérémy Garniaux via QGIS-User wrote:
> Hi,
> Version 2.2 (experimental) of the BADASS plugin has been available for a couple of days:
> https://plugins.qgis.org/plugins/badass/#plugin-about 1 <https://plugins.qgis.org/plugins/badass/#plugin-about>
> However it's doesn't seem to be visible from my (or my colleague's) QGIS install.
> Any idea why?
> Thanks,
> Jeremy
> Version de QGIS 	3.34.2-Prizren 	Révision du code 	7d199797fcc <https://github.com/qgis/QGIS/commit/7d199797fcc>
> Version de Qt 	5.15.10
> Version de Python 	3.11.6
> Version de GDAL/OGR 	3.7.1
> Version de Proj 	9.2.1
> Version de la base de données du registre EPSG 	v10.088 (2023-05-13)
> Version de GEOS 	3.12.0-CAPI-1.18.0
> Version de SQLite 	3.42.0
> Version du client PostgreSQL 	15.5 (Ubuntu 15.5-0ubuntu0.23.10.1)
> Version de SpatiaLite 	5.1.0
> Version de QWT 	6.1.4
> Version de QScintilla2 	2.14.1
> Version de l’OS 	Ubuntu 23.10
> Extensions Python actives
> QuickOSM 	2.2.3
> Qgis2threejs 	2.7.1
> qconsolidate3 	0.2.0
> profiletool 	4.2.6
> pgRoutingLayer 	3.0.2
> GeoCoding 	2.19
> TerrainShading 	0.9.4
> kart 	1.0.14
> koordinates 	3.0.0
> qgis-maptiler-plugin 	3.2
> cartogram3 	3.1.5
> mmqgis 	2021.9.10
> zoom_level 	0.1
> qgiscloud 	3.9.2
> SemiAutomaticClassificationPlugin 	8.2.0
> track_profile_2_web 	1.3
> geometry_paster 	0.4
> rvt-qgis 	0.9.6
> open_lidar_tools 	2.2.2
> qgis_resource_sharing 	1.0.0
> otbprovider 	2.12.99
> MetaSearch 	0.3.6
> processing 	2.12.99
> db_manager 	0.1.20
> grassprovider 	2.12.99
> Jérémy Garniaux
> https://mapper.fr
> https://mapstodon.space
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User mailing list
