[Qgis-user] Installation of QGIS on Ubuntu 22.4 LTS (Jammy) seems to use old library versions from 20.04 LTS (Focal)
chris hermansen clhermansen at gmail.com
Sat Jan 27 08:23:45 PST 2024
Maxime,
On Sat, Jan 27, 2024, 05:00 Schoemans Maxime <maxime.schoemans at ulb.be>
wrote:
> Hi Chris,
> Thank you for your response.
> On 27/01/2024 00:55, chris hermansen wrote:
> > Please post your /etc/apt/sources.list.d/qgis.sources
> *maxime at maxime-pc:~ $* lsb_release -cs
> jammy
> *maxime at maxime-pc:~ $* sudo cat /etc/apt/sources.list.d/qgis.sources
> Types: deb deb-src
> URIs: https://qgis.org/ubuntu
> Suites: jammy
> Architectures: amd64
> Components: main
> Signed-By: /etc/apt/keyrings/qgis-archive-keyring.gpg
> > It seems to me you may be getting the wrong set of packages.
> I was also under this impression, but I am not certain where I went wrong.
It somehow seems like you have the focal packages installed, though your
qgis.sources looks ok.
What happens if you do an apt update and apt upgrade on the command line?
Any errors?
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240127/05c3f88e/attachment.htm>
More information about the QGIS-User mailing list
