[Qgis-user] can't apply mask on labels
Andreas Neumann andreas at qgis.org
Wed Mar 6 12:29:24 PST 2024
Hi Emilie,
I believe that currently a limitation that a layer cannot mask itself.
For this to work, you'd have to duplicate the layer - once for the lines
and once for the labels - then the mask should work. On the label layer you
can disable the drawing of the lines and of course on the line layer you
only apply the mask from the other layer, but don't enable any labels.
Not sure if - or how soon this limitation can be fixed.
Hope this helps,
Andreas
On Wed, 6 Mar 2024 at 21:00, Émilie Berthiaume via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hi,
> I’m trying to apply a mask on the labels of my contour lines layer in a
> topographic map project.  I have activated the mask in the labels tab :
> And then I activated the symbol I wanted to hide in the mask tab :
> But it doesn’t seem to work.  There is still a line underneath my labels :
> Can anyone tell me what I am doing wrong?  Thank you,
> *Émilie Berthiaume*
> Enseignante
> Département de biologie et Techniques de bioécologie
> Ce message est confidentiel et est à l'usage exclusif du destinataire
> nommé ci-dessus. Si vous recevez ce message par erreur, sachez qu'il est
> interdit de le diffuser, de le distribuer, d'en dévoiler le contenu ou de
> le reproduire. Veuillez informer immédiatement l'expéditeur par courrier
> électronique et détruire l'original de ce message ainsi que toute copie.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Andreas Neumann
QGIS.ORG board member (treasurer)
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240306/8b8d4f7f/attachment-0001.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240306/8b8d4f7f/attachment-0001.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240306/8b8d4f7f/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240306/8b8d4f7f/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240306/8b8d4f7f/attachment-0005.png>
More information about the QGIS-User mailing list
