[Qgis-user] can't apply mask on labels
Sebastian Gutwein
bas at rdgland.com
Thu Mar 7 06:01:15 PST 2024
Andreas,
I think it can mask itself but you need to get it to refresh which takes
toggling the mask on another layer (or something- I haven't actually pinned
down when it refreshes)
In my attached screenshot you can see that there is only one layer and the
mask is applied and working on itself but it hasn't yet realized that I
removed the copy of the lyer I used to trigger the refresh.
[image: image.png]
On Wed, Mar 6, 2024 at 3:29 PM Andreas Neumann via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hi Emilie,
> I believe that currently a limitation that a layer cannot mask itself.
> For this to work, you'd have to duplicate the layer - once for the lines
> and once for the labels - then the mask should work. On the label layer you
> can disable the drawing of the lines and of course on the line layer you
> only apply the mask from the other layer, but don't enable any labels.
> Not sure if - or how soon this limitation can be fixed.
> Hope this helps,
> Andreas
> On Wed, 6 Mar 2024 at 21:00, Émilie Berthiaume via QGIS-User <
>> Hi,
>> I’m trying to apply a mask on the labels of my contour lines layer in a
>> topographic map project. I have activated the mask in the labels tab :
>> And then I activated the symbol I wanted to hide in the mask tab :
>> But it doesn’t seem to work. There is still a line underneath my labels :
>> Can anyone tell me what I am doing wrong? Thank you,
>> *Émilie Berthiaume*
>> Enseignante
>> Département de biologie et Techniques de bioécologie
>> Ce message est confidentiel et est à l'usage exclusif du destinataire
>> nommé ci-dessus. Si vous recevez ce message par erreur, sachez qu'il est
>> interdit de le diffuser, de le distribuer, d'en dévoiler le contenu ou de
>> le reproduire. Veuillez informer immédiatement l'expéditeur par courrier
>> électronique et détruire l'original de ce message ainsi que toute copie.
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Andreas Neumann
> QGIS.ORG board member (treasurer)
Sebastian "Bas* " Gutwein
*rhymes with Josh
Regenerative Design Group
1 Chevalier Ave
Greenfield, Ma 01301
Web: regenerativedesigngroup.com
(631) 241-1018
*Look close, think big, make change. *
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240307/2cda28cf/attachment-0001.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240307/2cda28cf/attachment-0001.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240307/2cda28cf/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240307/2cda28cf/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240307/2cda28cf/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240307/2cda28cf/attachment-0007.png>
More information about the QGIS-User
