[Qgis-user] QtWidgets.QFileDialog.getSaveFileName make qgis crash on windows 10
PLASSOT Eric e.plassot at laposte.net
Mon Mar 11 06:00:39 PDT 2024
with qgis 3.34 with a processing script in pythonthe use of the dialog
box QtWidgets.QFileDialog.getSaveFileNamemakes qgis crash on windows 10
and not on windows 11.
Maybe because the dialog is initiated in C/Program Files\QGIS 3.34.4\bin
which is a protected folder?I tried to set the document folder as
default, but same crash.
the code :
  output_file_name = input_featuresource.sourceName() + '.kml'
output_file_path, _ = QtWidgets.QFileDialog.getSaveFileName(None,
"Exporter les polygones au format KML",
output_file_name,
                                               "Fichiers KML (*.kml)")
I try this with the same crash when i click "Enregistrer"
  default_directory = os.path.join(os.path.expanduser("~"), "Documents")
os.path.join(default_directory,output_file_name),
The crash message :
## Report Details
**Python Stack Trace**
Windows fatal exception: access violation
Current thread 0x000015a8 (most recent call first):
File
"C:\Users\xxx\AppData\Roaming\QGIS\QGIS3\profiles\default\processing\scripts\exportPolygonsKMLParcellesAttributs.py",
line 201 in exportPolygonsKMLParcellesAttributs
"Exporter les polygones au format KML", output_file_name, "Fichiers KML
(*.kml)")
File
"C:\PROGRA~1/QGIS33~1.4/apps/qgis-ltr/./python\qgis\processing\algfactory.py",
line 278 in processAlgorithm
output = self._func(self, parameters, context, feedback, values)
Thread 0x000021d0 (most recent call first):
File
"C:\PROGRA~1/QGIS33~1.4/apps/qgis-ltr/./python/plugins\processing\ProcessingPlugin.py",
line 432 in executeAlgorithm
dlg.exec_()
File
"C:\PROGRA~1/QGIS33~1.4/apps/qgis-ltr/./python/plugins\processing\gui\ProcessingToolbox.py",
line 232 in executeAlgorithm
self.executeWithGui.emit(alg.id(), self, self.in_place_mode, False)
**Stack Trace**
QPainter::fillRect :
QWindowsStylePrivate::devicePixelRatio :
QWidgetPrivate::paintBackground :
QWidgetPrivate::drawWidget :
QWidgetPrivate::moveRect :
QWidget::event :
QApplicationPrivate::notify_helper :
QApplication::notify :
QgsApplication::notify :
QCoreApplication::notifyInternal2 :
QCoreApplicationPrivate::sendPostedEvents :
QEventDispatcherWin32::processEvents :
QEventLoop::exec :
QDialog::exec :
QFileDialog::getSaveFileUrl :
QFileDialog::getSaveFileName :
PyInit_QtWidgets :
PyObject_Str :
PyEval_EvalFrameDefault :
PyFunction_Vectorcall :
PyObject_GC_Del :
PyVectorcall_Call :
PyObject_Call :
pdal::PointContainer::freeTemp :
pdal::Option::getName :
QgsProcessingAlgorithm::runPrepared :
QgsProcessingAlgRunnerTask::run :
QgsTask::start :
QThreadPoolPrivate::reset :
QThread::start :
BaseThreadInitThunk :
RtlUserThreadStart :
**QGIS Info**
QGIS Version: 3.34.4-Prizren
QGIS code revision: decd43dc
Compiled against Qt: 5.15.3
Running against Qt: 5.15.3
Compiled against GDAL: 3.8.4
Running against GDAL: 3.8.4
**System Info**
CPU Type: x86_64
Kernel Type: winnt
Kernel Version: 10.0.19044
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240311/7f17efca/attachment-0001.htm>
Name: 2024-03-11 12_57_26-Exporter les polygones au format KML.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240311/7f17efca/attachment-0001.png>
More information about the QGIS-User mailing list
