[Qgis-user] Warning and errors netcdf when running a command
Langers, Fransje
fransje.langers at wur.nl
Fri Mar 15 03:17:14 PDT 2024
I will check that too! I had a QGIS course last week, where we changed some settings. I think I made a change too many.
-----Original Message-----
From: Andrea Giudiceandrea <andreaerdna at libero.it>
Sent: vrijdag 15 maart 2024 11:14
To: qgis-user at lists.osgeo.org
Cc: Langers, Fransje <fransje.langers at wur.nl>
Subject: Re: [Qgis-user] Warning and errors netcdf when running a command
> Langers, Fransje fransje.langers at wur.nl Fri Mar 15 01:05:24 PDT
> 2024
> This was indeed the situation. Thanks for solving my problem!
You are welcome. I suggest you to also ensure that the "Default output vector layer extension" is set to the value "gpkg" (GeoPackage), since I guess it is probably also incorrectly set to the "xtf" value which will also lead to issues with the GDAL processing algorithms having vector layer as output.
Since I suppose you have not intentionally set such options (like many other users experiencing similar issues), it would be very useful if you could remember what have you done after the last time the algorithm worked without issues and the first time it didn't work: have you upgraded / downgraded QGIS, or installed / uninstalled any plugin or used an older version and a newer version of QGIS with the same QGIS user profile, or...?
Every detail would help to find the root cause of the issue and try to permanently fix it.
Best regards.
Andrea
More information about the QGIS-User
