[Qgis-user] Problem with contour algorithm
boxerg at iinet.net.au boxerg at iinet.net.au
Mon Mar 18 15:16:05 PDT 2024
Yes, problem fixed as per reply. Many thanks
Grant
-----Original Message-----
From: Andrea Giudiceandrea <andreaerdna at libero.it>
Sent: Monday, March 18, 2024 9:43 PM
To: boxerg at iinet.net.au
Subject: Re: [Qgis-user] Problem with contour algorithm
Hi Grant,
have you managed to fix the issue? How?
Best regards.
Andrea
> Andrea Giudiceandrea andreaerdna at libero.it Thu Mar 14 08:47:37 PDT
> 2024
> Hi Grant,
> in order to fix the issue, you just need to change the "Default output
> vector layer extension" (in Settings->Options->Processing->General)
> for your QGIS user settings to a value other than "xtf": I suggest the
> value "gpkg" (GeoPackage) which is the default for such option.
> I also suggest you to also change the "Default output raster layer
> extension" to "tif", which probably may be also incorrectly set to "nc"
> in your QGIS user settings.
> Best regards.
> Andrea
More information about the QGIS-User mailing list
