[Qgis-user] qgis python error
Don Harter harterc2 at att.net
Thu Mar 21 11:36:41 PDT 2024
OK Thank you.
I am using a stable version from :
deb https://ppa.launchpadcontent.net/ubuntugis/ppa/ubuntu/ jammy main
I assume that is the latest stable version?
For linux software in general I try to stick with stable versions.
Oftentimes people make changes and submit them without being fully
tested.  Then I spend more time filling out bug reports instead of
working on my applications.
I upgraded the plugin and the error message did not appear.  I will see
if that holds on later runs of qgis.
On 3/21/24 1:47 PM, Etienne Trimaille wrote:
> Hi,
> You have installed the plugin "Value tool", you can remove it.
> You should report this issue to the plugin author, there is a bug
> tracker : https://github.com/jorgealmerio/valuetool
> You are using QGIS 3.22.4, you should try to upgrade as well, it's old.
> Le jeu. 21 mars 2024 à 17:49, Don Harter via QGIS-User
> <qgis-user at lists.osgeo.org> a écrit :
>     I am getting a python error now.  Does anyone know why I am
>     getting this now when earlier I wasn't?
>     An error has occurred while executing Python code:
>           ValueError: Unknown format code 'f' for object of type 'str'
>     Traceback (most recent call last):   File
>     "/home/drh/.local/share/QGIS/QGIS3/profiles/default/python/plugins/valuetool/valuewidget.py",
>     line 478, in printValue     self.labelStatus.setText(self.tr
>     <http://self.tr>('Coordinate:') + strFmt.format(position.x(),
>     position.y(),bandvalue)) ValueError: Unknown format code 'f' for
>     Python version: 3.10.12 (main, Nov 20 2023, 15:14:05) [GCC 11.4.0]
>     QGIS version: 3.22.4-Białowieża Białowieża, exported
>     _______________________________________________
>     QGIS-User mailing list
>     QGIS-User at lists.osgeo.org
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240321/5206b811/attachment.htm>
More information about the QGIS-User mailing list
