[Qgis-user] Adding virtual X & Y columns to a QGIS attribute form
oisin.kelly.wild at gmail.com oisin.kelly.wild at gmail.com
Thu Mar 21 15:34:30 PDT 2024
Once you have created the virtual field, you can add them to your form. Open form properties,go to form, choose drag and drop form designer, add the available attributes from left hand panel to middle panel. Right hand panel is for form widget settings.
Hope that helps
⁣Get BlueMail for Android ​
On 21 Mar 2024, 21:27, at 21:27, Brent Wood via QGIS-User <qgis-user at lists.osgeo.org> wrote:
>Hi,
>I have created an attribute form for a QGIS layer.
>I want to add two fields to the form: the X & Y values of a point
>geometry column.
>I can't find any way to do this - if I don't use the form, it is easy
>to add the virtual columns as expressions ($x & $y) in the table view,
>but I want these in the form view, not the table view.
>Any suggestions appreciated.
>Brent Wood
>Principal Technician, Fisheries
>NIWA
>DDI:  +64 (4) 3860529
>[https://www.niwa.co.nz/static/niwa-2018-horizontal-180.png]
><https://www.niwa.co.nz>
>Brent Wood
>Principal Technician - GIS and Spatial Data Management
>Programme Leader - Environmental Information Delivery
>+64-4-386-0529
>National Institute of Water & Atmospheric Research Ltd (NIWA)
>301 Evans Bay Parade Hataitai Wellington New Zealand
>Connect with NIWA: niwa.co.nz<https://www.niwa.co.nz>
>Facebook<https://www.facebook.com/nzniwa>
>LinkedIn<https://www.linkedin.com/company/niwa>
>Twitter<https://twitter.com/niwa_nz>
>Instagram<https://www.instagram.com/niwa_science>
>YouTube<https://www.youtube.com/channel/UCJ-j3MLMg1H59Ak2UaNLL3A>
>To ensure compliance with legal requirements and to maintain cyber
>security standards, NIWA's IT systems are subject to ongoing
>monitoring, activity logging and auditing. This monitoring and auditing
>service may be provided by third parties. Such third parties can access
>information transmitted to, processed by and stored on NIWA's IT
>systems.
>Note: This email is intended solely for the use of the addressee and
>may contain information that is confidential or subject to legal
>professional privilege. If you receive this email in error please
>immediately notify the sender and delete the email.
>_______________________________________________
>QGIS-User mailing list
>QGIS-User at lists.osgeo.org
>List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240321/a4ddb392/attachment.htm>
More information about the QGIS-User mailing list
