[Qgis-user] calculate areas of polygons imported from a dxf file
Zoltán Siki
siki1958 at gmail.com
Sat Mar 23 11:59:38 PDT 2024
Dear Jose,
I think you imported a line layer from the DXF file which has no area.
Convert the line layer to polygon one using Vector/Geometry tools/Lines to
Polygons from the menu.
Regards,
Zoltan
Jose Sanchez via QGIS-User <qgis-user at lists.osgeo.org> ezt írta (időpont:
2024. márc. 23., Szo, 19:30):
> Hi,
> I added a vector layer to QGIS 3.36.0 by importing a dxf file (it contains
> two polygons). I want to calculate the differentce in área of the polygons
> (considering the topography of a DEM file visualized in hillshade). So, I
> opened the attribute table, created a calculated field (ANRio) with the
> $area expression, but I get a NULL value. I see that my attribute table has
> NULL values for Paper Space and Line Type (I do not know if that might be
> the problem). I am probably not importing the polygons properly. I also
> tried importing as shape file using “anotherDXFimport” plugin but still I
> get NULL values in the area calculated field.
> I would appreciate your help.
> Thanks,
> Jose
> Imported polygons
> [image: Mapa Descripción generada automáticamente]
> Attribute tables
> [image: Interfaz de usuario gráfica, Aplicación Descripción generada
> automáticamente]
> Sent from Mail <https://go.microsoft.com/fwlink/?LinkId=550986> for
> Windows
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240323/302f99e8/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240323/302f99e8/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240323/302f99e8/attachment-0003.png>
More information about the QGIS-User
