[Qgis-user] Cross layer filtering
Bernd Vogelgesang
mail at berndvogelgesang.de
Fri Mar 29 14:05:29 PDT 2024
idea #1: Do not create a virtual layer (tried this way for years and its
still somehow a nightmare), but just duplicate you layer and switch it
to rule based rendering with a CASE WHEN clause for the selected property.
idea #2: I do not know what you exactly mean with "bring in an
associated layer" and how much of it you have to bring in, but maybe
aggregate functions in other virtual fields will do the job?
I just recently dived into the aggregate stuff, and there are not too
many good examples around. I find it pretty stable and did not encounter
any crashes like with virtual layers (it just works or not). Might take
a while for calculations (but that is just a question of hardware
upgrades ;) )
When this is just for layout purposes in the composer, rendering time
should not be as significant as well.
#3: Use themes!
When running into troubles, just ping me.
Cheers,
Bernd
p.s. maybe just bad ideas, but this just popped into my mind after my
third beer
Am 28.03.24 um 14:39 schrieb Paul Wittle via QGIS-User:
> Hi,
> I’ve been filtering a layer by adding a virtual column populated with
> is_selected() and then creating a virtual layer from it using the filter:
> WHERE virtualField = 1
> This is working well and allows you to have a copy of the layer that
> only shows the selected records when you are creating a layout.
> I now need to bring in an associated layer, but I can’t find a reliable
> way to cross layer filter because QGIS just hangs for ages and crashes.
> I’ve searched around and can see a lot of people talk about making the
> database do the work but of course it can’t if you are trying to use a
> selection filter.
> What is the most reliable way of setting up a filter based on a join
> because QGIS tells me that I must use a virtual layer and even creates
> it for me; but then it just hangs and crashes.
> Is there a better way?
> Info required to replicate:
> * Create a layer (mine is from Oracle DB) and add a virtual field
> called “SelectedRow” with the formula “to_int(is_selected())”
> * Bring in a second layer that has a one-to-many relationship based on
> an attribute
> * I’m trying to filter the second layer based on the first one where
> the second layer must only include rows that match a selected key.
> Thank in advance for any tips,
> Paul
> This e-mail and any files transmitted with it are intended solely for
> the use of the individual or entity to whom they are addressed. It may
> contain unclassified but sensitive or protectively marked material and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it,
> or disclose it to anyone else. If you have received this transmission in
> error please notify the sender immediately. All traffic may be subject
> to recording and/or monitoring in accordance with relevant legislation.
> Any views expressed in this message are those of the individual sender,
> except where the sender specifies and with authority, states them to be
> the views of Dorset Council. Dorset Council does not accept service of
> documents by fax or other electronic means. Virus checking: Whilst all
> reasonable steps have been taken to ensure that this electronic
> communication and its attachments whether encoded, encrypted or
> otherwise supplied are free from computer viruses, Dorset Council
> accepts no liability in respect of any loss, cost, damage or expense
> suffered as a result of accessing this message or any of its
> attachments. For information on how Dorset Council processes your
> information, please see www.dorsetcouncil.gov.uk/data-protection
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Dipl.-Geogr.
Bernd Vogelgesang
Kappel 17
91355 Hiltpoltstein
Tel: 09192-3499427
mobil: 0163-1860160
Type: text/vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240329/73207e97/attachment.vcf>
More information about the QGIS-User
