[QGIS-ZA-user] Georeferencing maps in QGIS
Neil Falconer nfalconersa at gmail.com
Mon Oct 9 01:34:02 PDT 2017
Hi Hanco,
One needs to be careful to make note of the projection info on topo and
geological maps. Essentially these maps may have a Decimal Degree graticule
around the border but the map is in fact projected. In such cases only the
decimal degree values of the corners of the map are in fact accurate.
In such instances one will need to first create a pont layer of those
corners in the correct projection as per the map. Only then use the
georeferencing tool to georeference the scanned map to those projected
corner points.
On Sun, Oct 8, 2017 at 2:16 PM, Hanco Roux via qgis-za-user <
qgis-za-user at lists.osgeo.org> wrote:
> Not having done this before and relatively new to QGIS can someone please
> assist me with georeferencing a topo or geological map into QGIS?
> Thank you in advance for the assistance.
> Hanco Roux (Pr.Sci.Nat.)
> Cell: 0837904575
> This email and any files transmitted with it are confidential and intended
> solely for the use of the individual or entity to whom they are addressed.
> If you have received this email in error please notify the system manager.
> This message contains confidential information and is intended only for the
> individual named. If you are not the named addressee you should not
> disseminate, distribute or copy this e-mail. Please notify the sender
> immediately by e-mail if you have received this e-mail by mistake and
> delete this e-mail from your system. If you are not the intended recipient
> you are notified that disclosing, copying, distributing or taking any
> action in reliance on the contents of this information is strictly
> prohibited.
> qgis-za-user mailing list
> https://lists.osgeo.org/mailman/listinfo/qgis-za-user
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20171009/4fce3a31/attachment.html>
More information about the qgis-za-user mailing list
