[QGIS-ZA-user] Scale Denominator in GeoServer
Gavin Fleming gavinjfleming at gmail.com
Fri Sep 15 06:51:39 PDT 2017
Hi Aphelele
What is your project CRS? My guess is that it’s 4326, where the scale varies considerably	depending on where you are (in fact scale in a geographic CRS is rather meaningless) . If you work in a projected CRS (which you should always do) it should behave as expected.
Gavin
> On 15 Sep 2017, at 15:32, Aphelele Dlayiya via qgis-za-user <qgis-za-user at lists.osgeo.org> wrote:
> Good day all.
> I have a situation with GeoSever/QGIS.
> I have created a style in GeoServer and and specified maximum scale of 1:90000 using the MaxScaleDenominator, example: <MaxScaleDenominator>90000</MaxScaleDenominator>
> My problem is that when I load the data in QGIS it only start drawing at scale 1:63000 instead of the 9000 I specified.
> I would appreciate some help on how to work around this.
> Kind regards
> Aphelele Dlayiya
> qgis-za-user mailing list
> https://lists.osgeo.org/mailman/listinfo/qgis-za-user
More information about the qgis-za-user mailing list
