[QGIS-ZA-user] aggregate crime attribute data from SAPS Station boundaries to Wards
Tim Sutton tim at kartoza.com
Tue Oct 2 04:38:07 PDT 2018
Hi Brian
This should be fairly easy to do in QGIS without using any special plugins if you don’t mind doing a few steps. Can you share the datasets you want to use with me and I will see if I can come up with an easy workflow for you?
Regards
Tim
> On 02 Oct 2018, at 10:57, Brian O'Leary via qgis-za-user <qgis-za-user at lists.osgeo.org> wrote:
> Dear QGis SA,
> I would like to know if there is a QGis tool that can assist with the following task.  I want to transfer crime attribute data from SAPS Station boundaries to Ward boundaries, assuming that crime is evenly distributed within the SAPS Station boundary.
> Previously I have done this task in Arc View using a script called DataPart.avx which was written by Jianwei Dou in 2002.  The below simplified sketch illustrates what I am trying to do in Qgis.  The SAPS Station shape has the data attributes and the Ward shape is the overlay or boundary shape. The output that I need is an attribute table that has calculated the % intersection of the SAPS Station by the ward boundaries and aggregated the crime attributes to a Ward table based on the % intersection.  In the below sketch the ward boundaries intersect the SAPS Station boundary by 50% in both cases.  As there were 100 crimes in the SAPS Station boundary the output table lists Wards 1 and 2 with 50 crimes in each.
> <image.png>
> Any advise most welcome.
> Regards
> Brian O'Leary
> qgis-za-user mailing list
> https://lists.osgeo.org/mailman/listinfo/qgis-za-user
Tim Sutton
Co-founder: Kartoza
Ex Project chair: QGIS.org
Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
Desktop GIS programming services
Geospatial web development
GIS Training
Consulting Services
Skype: timlinux
IRC: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20181002/34be6f1d/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20181002/34be6f1d/attachment-0001.jpg>
More information about the qgis-za-user mailing list
