[QGIS-ZA-user] How to add Google Earth Satellite on Qgis
Gavin Taylor gavin.taylor.gis at gmail.com
Sat Sep 5 21:19:16 PDT 2020
Hi Mahlape
If you run this script in your python console it will automatically add a
bunch of xyz tile layers for you to use as base maps:
https://github.com/klakar/QGIS_resources/blob/master/collections/Geosupportsystem/python/qgis_basemaps.py
If you are on a company network then you may need to change the proxy
settings in Qgis for the layers to render.
Regards
Gavin
On Sun, 06 Sep 2020, 6:48 AM Mahlape Ramahloko via qgis-za-user, <
qgis-za-user at lists.osgeo.org> wrote:
> Thank you for your response.
> Regards
> On Fri, Sep 4, 2020 at 4:25 PM Frank Sokolic via qgis-za-user <
>> Dear Mahlape,
>> You can do it by installing the QuickMapServices plugin from the Plugin
>> menu and then activating the "Contributed Pack" by clicking:
>> Web > QuickMapServices > Settings > More services > Get contributed pack.
>> Now you can go to Web > QuickMapServices > Google and select the Google
>> layer you need.
>> Regards, Frank.
>> On 2020/09/04 14:46, Mahlape Ramahloko via qgis-za-user wrote:
>> Good Afternoon,
>> I am trying to add Google Earth Image in QGIS. I right clicked on XYZ
>> tiles and selected new connections. I copied and pasted the URL address
>> that I found on Google earth website. This is the URL I used and nothing
>> happened. Kindly assist.
>> https://earth.google.com/web/@0,0,0a,22251752.77375655d,35y,0h,0t,0r
>> regards
>> qgis-za-user mailing listqgis-za-user at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/qgis-za-user
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20200906/d533e97b/attachment.html>
More information about the qgis-za-user mailing list
