[STDM-dev] Fwd: Installers for STDM
John Gitau John.Gitau at unhabitat.org
Mon Jun 8 06:11:39 PDT 2015
Dear Steve,
Yes, you can definitely use it but you will need to do a manual copy of the plugin folder by checking it out from the GitHub repository: https://github.com/gltn/stdm.git and manually creating the template database (this will not interfere with your current setup). Let me know if you further guidance on this.
John Gitau
Land and GLTN Unit, Urban Legislation, Land and Governance Branch | UN-HABITAT
NOF Block 3 Level 3 South Wing I P.O. Box 30030-00100 Nairobi, Kenya
Tel: + 254 20 762 3032 | +254 (0)722 945 556
Website:www.unhabitat.org | Partners' website:www.gltn.net
-----stdm-dev-bounces at lists.osgeo.org wrote: -----
To: stdm-dev at lists.osgeo.org
Sent by: stdm-dev-bounces at lists.osgeo.org
Date: 06/08/2015 12:32PM
Subject: [STDM-dev] Fwd: Installers for STDM
Bounced and forwarded:
-------- Forwarded Message --------
Subject: Installers for STDM
Date: Sat, 6 Jun 2015 12:50:16 +0300
Hello,
I want to install STDM but I need to ask more about the Installers, that
is QGIS, postgres and postgis.
Well I already have higher versions of these running on my machine and
as I could see STDM is based on very low version of the same so my
question is, can I implement STDM on my machine with the current setup
so that I can use my QGIS2.8, postgre 9.4 and postgis 2.1 without having
to interfere with my current services.
I will appreciate you help please.
Regards,
Ochieng' Steve
STDM-dev mailing list
STDM-dev at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/stdm-dev
URL: <http://lists.osgeo.org/pipermail/stdm-dev/attachments/20150608/d70bb376/attachment.html>
More information about the STDM-dev mailing list
