[STDM-user] Help for Use of STDM and authentication
John Gitau John.Gitau at unhabitat.org
Fri Dec 2 02:03:07 PST 2016
Hi Madhy,
The error notification basically indicates that the STDM database being used does not have PostGIS enabled. Do you have PostGIS installed? If not, follow the instructions here, otherwise you will need to add the PostGIS extension to this specific database. Using pgAdminIII tool (bundled together with the PotgreSQL installation):
Log into the database server;
Click to select the stdm database;
Click on the SQL icon to open a new window for entering the SQL command(s);
Paste the following command: CREATE EXTENSION postgis;
While still in the Query Editor window, select the following menu item: Query > Execute;
Try to log in again, it should work now;
Follow the steps outlined under First Time Login section to proceed with the initial configuration: http://stdm.gltn.net/docs/1_4/#t=logging_in_to_STDM.htm
Regards,
John Gitau
Land and GLTN Unit, Urban Legislation, Land and Governance Branch | UN-HABITAT
NOF Block 3 Level 3 South Wing I P.O. Box 30030-00100 Nairobi, Kenya
Tel: + 254 20 762 3032 | +254 (0)722 945 556
Website:www.unhabitat.org | Partners' website:www.gltn.net
-----"STDM-user" <stdm-user-bounces at lists.osgeo.org> wrote: -----
To: stdm-user at lists.osgeo.org
Sent by: "STDM-user"
Date: 12/01/2016 11:07PM
Subject: [STDM-user] Help for Use of STDM and authentication
Hello
I installed the STDM plugin in QGIS 2.14 and when I wanted to connect
I get this message: "STDM can not loaded because the system has detected that PostGIS extension is missing in STDM database.
Check that PostGIS has been installed and that the extension has been enabled in the STDM database. Please contact the sytem administrator for more information. "
Can you help me to solve this problem?
Thanks for your understanding
CHERIF Aidara Madhy
Geomaticien Master I CURAT/EDAT
Spécialité: Télédetection-SIG-Amenagement Gestion des Terre et des Ecosysteme (AGTE), Economie portuaire et maritime, Pêche
*Ecole Doctoral Africaine de Télédétection
*Centre Universitaire de Recherche et d'application en Télédetection
email: cherif_900 at yahoo.frcherifmad at gmail.com
Contact:  09096707
27 BP 202 Abidjan 27
STDM-user mailing list
STDM-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/stdm-user
URL: <http://lists.osgeo.org/pipermail/stdm-user/attachments/20161202/d0ca941d/attachment.html>
More information about the STDM-user mailing list
