[STDM-user] STDM LOGIN
Maureen Omino
maureen.omino at gmail.com
Mon Sep 11 01:22:04 PDT 2017
Hi Guys
seems like am still having problems,am trying to reset the password by
going through this *C:\Program Files\PostgreSQL\9.x[1]\data* and locate the
file named *pg_hba.conf* and i cant find the file pg-hba.conf,i have also
tried to unistalled everything but the postgres username created while
installation is still a problem because it wont do away or get deleted,guys
how can i get rid of it and start the instalation from the beginning
because i also tried installing the stdm software in another computer and
its working pretty well
On Fri, Sep 8, 2017 at 1:10 PM, John Gitau <John.Gitau at unhabitat.org> wrote:
> See the instructions for resetting the password in the user manual:
> http://www.stdm.gltn.net/docs/1_5/#t=Resetting_PostgreSQL_Password.htm
> Regards,
> John Gitau
> -----Maureen Omino <maureen.omino at gmail.com> wrote: -----
> To: John Gitau <John.Gitau at unhabitat.org>
> From: Maureen Omino <maureen.omino at gmail.com>
> Date: 09/08/2017 01:05PM
> Cc: stdm-user at lists.osgeo.org, Paul Gathogo <pgathogo at gmail.com>
> Subject: Re: [STDM-user] STDM LOGIN
> Thanks so much but it seems like i have forgotten the password,Kindly what
> should do?
> On Fri, Sep 8, 2017 at 12:52 PM, John Gitau <John.Gitau at unhabitat.org>
> wrote:
>> Hi Maureen,
>> In addition to Paul's comments, please have a look at how to reset the
>> password for the 'postgres' account here: http://www.stdm.gltn.net
>> The error message that you are getting basically indicates that the user
>> account 'omino86' was not assigned to any specific security role. In order
>> to assign it, you will need to still need to log in using the 'postgres'
>> user account to edit the security settings of 'omino86' user account, more
>> information on this is available here: http://www.stdm.gltn.net
>> /docs/1_5/#t=rolemanagement.htm
>> Regards,
>> John Gitau
>> Land and GLTN Unit, Urban Legislation, Land and Governance Branch |
>> UN-HABITAT
>> NOF Block 3 Level 3 South Wing I P.O. Box 30030-00100 Nairobi, Kenya
>> Tel: + 254 20 762 3032 | +254 (0)722 945 556
>> Skype: kahiu.gitau
>> Website:www <http://www.unhabitat.org>.unhabitat.org
>> <http://www.unhabitat.org> | Partners' website:www <http://www.gltn.net>
>> .gltn.net <http://www.gltn.net>
>> -----Paul Gathogo <pgathogo at gmail.com> wrote: -----
>> To: Maureen Omino <maureen.omino at gmail.com>
>> From: Paul Gathogo <pgathogo at gmail.com>
>> Date: 09/08/2017 12:30PM
>> Cc: stdm-user at lists.osgeo.org, John Gitau <John.Gitau at unhabitat.org>
>> Dear Maureen,
>> I'm sorry for the troubles you having accessing STDM. Currently STDM only
>> support user account 'postgres'. This is the user account you setup during
>> installation. If you installed STDM yourself and you remember the password
>> for user 'postgres', please try to login as user 'postgres' and with an
>> appropriate password for the account.
>> Kindly revert in case of any challenges.
>> Regards,
>> Paul Gathogo
>> On Fri, Sep 8, 2017 at 12:04 PM, Maureen Omino <maureen.omino at gmail.com>
>> wrote:
>>> Dear All
>>> Kindly can someone help me with this,Am trying to log into stdm and its
>>> not successfull giving back this message
>>> u"'omino86' must be a member of at least one STDM role in order to
>>> access the modules.\nPlease contact the system administrator for more
>>> information."
>>> What could be the problem?
>>> Many thanks
>>> Maureen Omino
>>> STDM-user mailing list
>>> STDM-user at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/stdm-user
>> *Everything we call real is made of things that cannot be regarded as
>> real.*
URL: <http://lists.osgeo.org/pipermail/stdm-user/attachments/20170911/270e2e16/attachment.html>
More information about the STDM-user
