[webmap-discuss] OGC and google style tiling
Paul Spencer pspencer at dmsolutions.ca
Fri Apr 14 08:42:44 EDT 2006
Ok.  I'm not sure if the URLs to the tiles are standard.  The URL
goes to a tile.php script which converts special pixel coordinates
into geographic coordinates.  The math for the conversion is very
simple though, all you need to know is the size of a pixel in
I'll need to look into mapbuilders controls to understand how to do
the integration.  Perhaps this could be the start of a common API? ;)
Cheers
Paul
On 13-Apr-06, at 11:33 PM, Cameron Shorter wrote:
> The "standard URL" I was refering to is the URL of a tile.
> Both ka-map and mapbuilder have both implemented much of the same
> functionality.  We will need to work out a logical place to split
> between the ka-map code and the mapbuilder code.
> I think it would be difficult to use Mapbuilder without Mapbuilder
> controls.  Probably what we would need to do is convert your ka-map
> tools to fit within the Mapbuilder framework.
> Paul Spencer wrote:
>> Cameron,
>> what do you mean by standard url?  ka-Map has a javascript API
>> that  handles all the navigation including the smooth panning of
>> the map.   While not exactly like google, the api is roughly
>> equivalent.
>> Not sure if you could use mapbuilder's controls or not, it would
>> be  cool if you could.
>> I'll take a stab at installing/running MapBuilder this weekend.
>> Do I  need to do anything special to use the Google Map layer?
>> Cheers
>> Paul
>> On 13-Apr-06, at 6:26 AM, Cameron Shorter wrote:
>>> Paul,
>>> I'm currently allowing a Google Map layer to be included as one
>>> of  the layers rendered by Mapbuilder.
>>> So if you have a standard URL used to call a tiled map server,
>>> then  we can create a Mapbuilder Layer which accesses the URL
>>> (we'd  probably base our code on your existing ka-maps code).
>>> I'd expect that we would use the Mapbuilder pan/zoom type tools
>>> and  buttons rather than the ka-map tools.
>>> Is that what you were thinking about?
>>> Paul Spencer wrote:
>>>> What would be really nice would be to have a MapBuilder widget
>>>> for  ka- Map ;)  Mike Adair has mentioned that this is both
>>>> possible  and quite  easy to do.  Not being very familiar with
>>>> MapBuilder, I  can't comment  on that.  But if it were possible
>>>> to do, ka-Map  would provide you a  tiled interface and you
>>>> could use your  existing map file to do it  without breaking ogc
>>>> compatibility.
>>>> Cheers
>>>> Paul
>>>> On 12-Apr-06, at 4:33 AM, Steven M. Ottens wrote:
>>>>> Hi Bart,
>>>>> Thanks for the mailinglist tip.
>>>>> It might be possible to rasterize our vector data, but we've
>>>>> got  quite
>>>>> some datasets and there will be more of them. It also makes us
>>>>> less
>>>>> flexible. Obviously we've to make a trade-off on flexibility
>>>>> and   speed.
>>>>> We hope that with cached tiles we can have both the flexibility
>>>>> and
>>>>> speed. If we rasterise it would make sense to rasterise into
>>>>> fixed  tiles
>>>>> I guess.
>>>>> Steven
>>>>> Bart van den Eijnden wrote:
>>>>>> Hi Steven,
>>>>>> there is an OGC list to discuss tiling:
>>>>>> http://lists.eogeo.org/mailman/listinfo/tiling
>>>>>> check the archives there.
>>>>>> What you could also do, since I assume your data is pretty
>>>>>> much   static, is
>>>>>> use UMN Mapserver to rasterize all your vector data (create
>>>>>> Geotiffs e.g.)
>>>>>> and serve out the rasters instead. I guess the
>>>>>> classifications   used are
>>>>>> heavy on CPU usage, and pre-classified rasters would solve
>>>>>> that   part at
>>>>>> least.
>>>>>> Best regards,
>>>>>> Bart
>>>>>>> Hi all,
>>>>>>> For those who don't know: I'm one of the lead developers on
>>>>>>> the  EduGIS
>>>>>>> project, a site which aims to introduce highschool students
>>>>>>> to   GIS. The
>>>>>>> site contains a webmapping part, which combined with so called
>>>>>>> 'lesson-modules' can be used inside the classroom.
>>>>>>> We aim to be able to have at least 200 students access the
>>>>>>> site  at one
>>>>>>> time. Since it's being used inside the classroom it means
>>>>>>> that  a  lot of
>>>>>>> students will do more or less the same thing at the same
>>>>>>> time   (following
>>>>>>> the tasks in the lesson-modules). This causes quite some
>>>>>>> stress  on the
>>>>>>> server. Since it's a free site we have limited budget and
>>>>>>> cannot  put a
>>>>>>> google-style server park behind it ;(
>>>>>>> Right now we've got apache to serverside cache the umn
>>>>>>> mapserver  output.
>>>>>>> This obviously works only for those images that are
>>>>>>> requested  twice
>>>>>>> (like the first mapimage). Right now about 30 students can
>>>>>>> work  at the
>>>>>>> same time without it becoming unworkable slow. Since
>>>>>>> serverside  caching
>>>>>>> works, the next logical step to boost performance would be
>>>>>>> using  tiles
>>>>>>> like google.
>>>>>>> But..
>>>>>>> From what I know, tiling breaks OGC compatibility, right?
>>>>>>> We're using Mapbuilder as client and we prefer to keep using
>>>>>>> it,  since
>>>>>>> it's turning into a rather featureful client on the EduGIS
>>>>>>> site.  But the
>>>>>>> question arises how to implement tiling inside WMC/OWS-
>>>>>>> context   without
>>>>>>> breaking OGC too much.
>>>>>>> Also I'm interested in the used algorithms to get tiling
>>>>>>> working.
>>>>>>> Cheers,
>>>>>>> Steven
>>>>>>> To unsubscribe, e-mail: webmap-discuss-
>>>>>>> unsubscribe at mail.osgeo.org
>>>>>>> For additional commands, e-mail: webmap-discuss-
>>>>>>> help at mail.osgeo.org
>>>>>> To unsubscribe, e-mail: webmap-discuss-unsubscribe at mail.osgeo.org
>>>> |Paul Spencer                           pspencer at dmsolutions.ca   |
>>>> |Applications & Software Development                              |
>>>> |DM Solutions Group Inc                 http://www.dmsolutions.ca/|
>>>> For additional commands, e-mail: webmap-discuss-help at mail.osgeo.org
>>> Cameron Shorter
>>> http://cameron.shorter.net
> Cameron Shorter
More information about the Webmap-discuss mailing list
