[Mapbuilder-users] Printing multiple layers
Cameron Shorter cameron.shorter at gmail.com
Thu Nov 23 13:08:01 EST 2006
Paul,
I understand you worked out how to print in IE (setting Opacity somewhere).
Could you please point Jason at an example webmap which will print in IE
so that we can copy the DOM.
Jason, once you have something that does print, have a lot at its DOM
(you can use Firefix Tools->DOM Inspector. Right click on HTML select
Copy XML.)
Then you will need to tweak MapPane.xsl until the Mapbuilder DOM looks
similar.
phatbloke at world-net.co.nz wrote:
> Hi
> I'm really getting stuck on this one. So far I have a perfectly
> working mapbuilder page but I can't print a copy of it. In IE my
> prints only print the top layer even though print preview looks
> perfect. In FF I get a completly black window again even though print
> preview looks perfect. I have had a play with the opacity settings
> with no luck and had a look at Deegree as mentioned below but couldn't
> find any real documentation regarding the Web Map Print Service. I see
> the solution is really to export a pdf from the server side as all
> other map projects seem to do (ie Mapbender) but am not sure if anyone
> has been sucessful at this. There was some discussion on the matter
> back in March.
> Does anyone have any ideas?
> Jason
> Quoting "Bart van den Eijnden (OSGIS)" <bartvde at osgis.nl>:
>>One option would be to do the printing server-side, you could for instance
>>use the Web Map Print Service from the Deegree project (www.deegree.org).
>>Best regards,
>>Bart
>>OSGIS, Open Source GIS
>>http://www.osgis.nl
>>--------- Oorspronkelijk bericht --------
>>Van: phatbloke at world-net.co.nz
>>Naar: mapbuilder-users at lists.sourceforge.net
>><mapbuilder-users at lists.sourceforge.net>
>>Onderwerp: [Mapbuilder-users] Printing multiple layers
>>Datum: 14/11/06 07:57
>>>Hi
>>>I have the issue and read some earlier posts that mapbuilder has an
>>>cannot print a layout with several layers and only prints the top
>>>layer due to transperancy issues etc. Has anyone found a work around?
>>>Any ideas?
>>>Jason
>>>Using Tomcat but need to do more? Need to support web services, security?
>>>Get stuff done quickly with pre-integrated technology to make your job
>>easier
>>>Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
>>http://sel.as-us.falkag.net/sel?cmd=lnk&amp;kid=120709&amp;bid=263057&amp;dat=121642
>>>_______________________________________________
>>>Mapbuilder-users mailing list
>>>Mapbuilder-users at lists.sourceforge.net
>>>https://lists.sourceforge.net/lists/listinfo/mapbuilder-users
> Take Surveys. Earn Cash. Influence the Future of IT
> Join SourceForge.net's Techsay panel and you'll get the chance to share your
> opinions on IT & business topics through brief surveys - and earn cash
> http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV
Cameron Shorter
http://cameron.shorter.net
More information about the Webmap-discuss mailing list
