[webmap-discuss] OpenLayers/ka-Map Merging BOF Results
Lorenzo Becchi lorenzo at ominiverdi.com
Thu Sep 14 10:40:34 EDT 2006
Good work Chris,
as I've seen on rss Schuyler started posting some comments on the wiki.
http://wiki.osgeo.org/index.php/FOSS4G_2006_Tiling_BOF
Please everybody who was there help refining.
ciao
Lorenzo
On 14/set/06, at 15:22, Christopher Schmidt wrote:
> So, the OpenLayers/Ka-Map merger BOF was much more than that -- in
> fact,
> it was a similar gathering to the tiling BOF, in that every web map
> client was well represented at the session and the goal was a
> consensus,
> with possibly some compromises, which would suit all persons involved.
> After much discussion, we came down to the idea of a general set of
> functionality that all webmapping client developers could use --
> specifically, it should be possible to take any div on a page, and
> draw
> a map inside that div using this library. The library will work in
> such
> a way that it will have the following bits of code:
>  * Map
>  * Layer
>  * A few useful subclasses of layer (WMS)
>  * Event handling
> The idea is to make a small library for displaying image tiles in a
> div,
> and make everything else up to the application. Doing this means
> that we
> can combine the work on actually doing tiled map drawing -- a tile
> renderer is something that many people, from Ka-Map to MapBuilder to
> maybe MapBender, MapGuide, etc. could use.
> The core of this is going to be a small subset of OpenLayers which
> does not
> depend on Prototype: Essentially, the Map, Layer, and Events
> classes we
> have currently developed will be modified such that they can fit in
> with
> other clients as well as possible. The goal is to pick a limited
> subset
> of useful infrastructure, and attempt to make it possible for all web
> mapping applications -- OpenLayers, kaMap, and others -- to be
> built on
> top of it. To do that, a limited subset of a tile rendering engine is
> neccesary.
> We're going to have a goal of a draft version of the newly discussed
> "WebMap.js" in the next 2 months ish, with the hopes of making sure
> that
> all projects who are interested -- from MapGuide to OpenLayers --
> can be
> built on top of the framework, with no dependancies which block other
> development.
> I've been working on this email for far too long -- so, I'll send it,
> and hopefully in the relatively short term, it can start being
> backed up
> with code.
> Please feel free to augment this post with further exlanation and
> discussion :)
> Regards,
> Christopher Schmidt
> MetaCarta
> To unsubscribe, e-mail: webmap-discuss-unsubscribe at mail.osgeo.org
> For additional commands, e-mail: webmap-discuss-help at mail.osgeo.org
More information about the Webmap-discuss mailing list
