[ZOO-Discuss] ZOO Web Client ideas
rldhont rldhont at gmail.com
Fri Nov 13 04:54:58 PST 2009
Hi Jachym,
Do you have something more graphic than source code to understand the
pyWPS WPS JavaScrip Object ?
René-Luc D'Hont
Jachym Cepicky a écrit :
> hi, again,
> On Fri, Nov 13, 2009 at 11:33:35AM +0100, rldhont wrote:
>> Eric Lemoine a écrit :
>>> On Friday, November 13, 2009, rldhont <rldhont at gmail.com> wrote:
>>>> Hi All,
>>>> I think DescribeProcess could be use to create object to control
>>>> mandatory parameters, datatypes and mimetypes. It will be usefull, isn't
>>>> it ?
>>> sorry I don't get what you mean. Could you elaborate a bit please?
>>> Thanks,
>> In a describe process, we could find parameter's name, parameter's
>> mandatory, parameter's datatype or mimetype.
>> Based on a describeProcess, it's possible to construct a JavaScript
>> Object which could validate a process request. I think DescribeProcess
>> must be used to do this.
> yes, this is all solved in the WPS.js comming with PyWPS. But I would
> like to, if somebody would help with it's development
> Jachym
More information about the Zoo-discuss mailing list
