[ZOO-Discuss] GRASS WPS Process Description
Markus Neteler markus.neteler at iasma.it
Fri Nov 27 13:12:03 PST 2009
Hi all,
yes, it's there now!
GRASS 7: new WPS process description can be automatically
generated thanks to Soeren
http://grass.osgeo.org/wiki/WPS
On Fri, Nov 27, 2009 at 09:14, rldhont <rldhont at gmail.com> wrote:
> Well Gérald, What do you think about it ? Do you have to create a GRASS
> Provider, like C or Python ? How to re-use this capability ?
Would be great! The new direct support in GRASS should make things
finally easier.
Markus
PS:
Example:
 r.external --wps-process-description
     <wps:process_descriptions xmlns:wps="http://www.opengis.net/wps/1.0.0"
     xmlns:ows="http://www.opengis.net/ows/1.1"
     xmlns:xlink="http://www.w3.org/1999/xlink"
     xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
     xsi:schemaLocation="http://www.opengis.net/wps/1.0.0
      http://schemas.opengis.net/wps/1.0.0/wpsDescribeProcess_response.xsd"
      service="WPS" version="1.0.0" xml:lang="en-US">
       <process_description wps:processVersion="1"
storeSupported="true" statusSupported="true">
                               <ows:Identifier>r.external</ows:Identifier>
                               <ows:Title>Link GDAL supported raster
file to a binary raster map layer.</ows:Title>
                               <ows:Abstract>Link GDAL supported
raster file to a binary raster map layer.</ows:Abstract>
               <ows:Metadata xlink:title="raster" />
               <ows:Metadata xlink:title="import" />
               <data_inputs>
                       <Input minOccurs="0" maxOccurs="1">
                               <ows:Identifier>input</ows:Identifier>
                               <ows:Title>Raster file to be linked</ows:Title>
                               <ows:Abstract>Raster file to be
linked</ows:Abstract>
                               <LiteralData>
                                       <ows:DataType
ows:reference="xs:string">string</ows:DataType>
                                       <ows:AnyValue/>
                               </LiteralData>
                       </Input>
                                               <Format>
<MimeType>application/grass-raster-binary</MimeType>
                                               </Format>
                                       </Supported>
                               </ComplexOutput>
                       </Output>
               </process_outputs>
       </process_description>
     </wps:process_descriptions>
More information about the Zoo-discuss mailing list
