[ZOO-Discuss] Absysseo LBS SDK similar to ZOO-kernel & Geopard
Jonathan-David SCHRODER jonathan.schroder at gmail.com
Wed Apr 7 14:51:50 PDT 2010
Hello,
I am writing this on the ZOO-kernel list for info as to how Geopard wants to
position itself on the indoor location-based-services market
namely thanks to the ZOO-kernel.
Recently, I have found out about Absysseo ( http://www.absysseo.com/ ).
The company proposes an editor+mobile client+server kit for indoor mapping
able to plug with any geopositioning system.
Their product is implemented in .NET for the server and editor side and
MIDP/J2ME (java) for the mobile application proprietary with a proprietary
map format.
They have a SDK named Absysseo Development Kit (
http://www.absysseo.com/produits-services.php > ADK ), enabling third-party
developers to add new location-based services. Typically, I'd assume the SDK
allows adding new kind of map objects and new per-map-object-type associated
web APIs & dialogs.
Geopard is an indoor wifi geopositioning solution relying on openstreetmap
for the server stack with OSM v0.6 API, KML and SQLite webservices, the JOSM
editor with an in-house plugin to help drawing indoor maps and a Nutiteq
J2ME maps lib -based client. All components there are open source or will be
(the KML & SQLite webservices + the indoor JOSM plugin).
We hope that using the ZOO-kernel will help us adding
location-based-services more cleanly similary to what the ADK does.
Our first development goal is to have a robust and triplet (editor, client,
server) based on an OSM server, where all webservices are reachable through
either simple HTTP URLs or a OGC WPS interface. Later on, we'd use other map
server implementations behind the webservices layer.
Take care,
Jonathan-David Schröder
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20100407/5eb2f404/attachment.html>
More information about the Zoo-discuss mailing list
