[ZOO-Discuss] ZOO Kernel 1.0 Release
Gérald Fenoy gerald.fenoy at geolabs.fr
Mon Apr 19 02:21:44 PDT 2010
Hi Sarawut,
I'm sure about what constrain you to be root, it depends on your specific Apache installation I think.
Indeed, if you get some directory where you can write to make your content available through the Apache Server and can get some directory where to put cgi scripts then you should be able to install without need to be root.
Hope it helps;
Le 19 avr. 2010 à 09:55, Sarawut Ninsawat a écrit :
> Hi Gerald,
> Thank you for your great work.
> I am installing also but just wonder that is it possible to install
> without root permission ?
> Sarawut
> Gérald Fenoy wrote:
>> Hi Lucas,
>> it seems that your .htaccess file wasn't used by your Apache server.
>> Maybe you get AllowOverride None somewhere in your apache config ?
>> If you can''t use the RewriteRules, you should be able to test your
>> ZOO Kernel installation using this url
>> : http://127.0.0.1/cgi-bin/zoo_loader.cgi?ServiceProvider=&metapath=&Service=WPS&Request=GetCapabilities&Version=1.0.0
>> <http://127.0.0.1/cgi-bin/zoo_loader.cgi?ServiceProvider=&metapath=&Service=WPS&Request=GetCapabilities&Version=1.0.0>
>>> when i try
>>> http://127.0.0.1/zoo/?Service=WPS&Request=GetCapabilities&Version=1.0.0
>>> <http://127.0.0.1/zoo/?Service=WPS&Request=GetCapabilities&Version=1.0.0>
>>> the server return the page of my directory
>>> Index of /zoo
>>> [ICO] Name Last modified Size Description
>>> [DIR] Parent Directory -
>>> Apache/2.2.12 (Ubuntu) Server at 127.0.0.1 Port 80
>>> maybe the problem is in the .htaccess file when define the RewriteRule?
>>> It seems the RewriteRule is looking in the folders ../.. instead for
>>> my configuration it must search in /usr/lib/cgi-bin
>> Hope this help,
>> Djay
>> Just a ZOO Tribe Member
>> gerald.fenoy at geolabs.fr <mailto:gerald.fenoy at geolabs.fr>
>> Zoo-discuss mailing list
>> Zoo-discuss at gisws.media.osaka-cu.ac.jp
>> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
> Dr. Sarawut NINSAWAT
> GEO Grid Research Group
> Information Technology Research Institute
> National Institute of Advanced Industrial Science and Technology (AIST)
> Central 2, 1-1-1 Umezono, Tsukuba 305-8568, Japan
> E-mail: sarawut.ninsawat at aist.go.jp
> Tel: 81-29-862-6702 ext. 55036
> Fax: 81-29-862-6601
Djay
More information about the Zoo-discuss mailing list
