[ZOO-Discuss] [ZOO Project Trac] #11: Kernel segfaults when metapath parameter is missing from request
ZOO Project Trac zoo-dev at cartography.st
Tue Aug 24 04:50:42 PDT 2010
Reporter:  relet   |       Owner:
    Type:  defect  |      Status:  new
Priority:  major   |   Component:  zoo-kernel
 Version:  1.0     |    Keywords:
 More specifically -
 When {{{ServiceProvider}}} and {{{metapath}}} parameters are not present,
 it will complain that {{{ServiceProvider}}} is missing
 When {{{ServiceProvider}}} is present, but {{{metapath}}} is not, kernel
 segfaults.
 When {{{metapath}}} is present, but {{{ServiceProvider}}} is not, it will
 silently abort in the middle of the output. The result may look like this:
 80
 +Content-Type: text/xml; charset=utf-8
 Status: 200 OK
 All of the above should yield a correct xml error message.
Ticket URL: <http://svn.zoo-project.org/trac/ticket/11>
ZOO Project Trac <http://svn.zoo-project.org/>
Open WPS Platform
More information about the Zoo-discuss mailing list
