[ZOO-Discuss] Premature end of script headers: zoo_loader.cgi on Windows
Yingqi Tang
anakintang at gmail.com
Sat Jul 10 13:34:04 PDT 2010
Hi Gérald,
I really appreciate your quick response, but still no luck for me and I'm
still getting only the header along with a app crash. So probably I need to
try it on another machine. By the way do I need to install any c++ runtime,
visual studio or so?
Thanks,
Yingqi
On Sat, Jul 10, 2010 at 9:50 AM, <gerald.fenoy at geolabs.fr> wrote:
> Hı Yıngqı,
> I uploaded the fıle agaın (but ın the rıght dırectory thıs tıme), please
> can you try to download agaın ?
> I tested and ıt should work,
> Regards,
> Djay
> ---- Envoyé avec BlackBerry® d'Orange ----
> *From: * Yingqi Tang <anakintang at gmail.com>
> *Date: *Sat, 10 Jul 2010 07:12:06 -0700
> *To: *Gérald Fenoy<gerald.fenoy at geolabs.fr>
> *Cc: *ZOO-discuss<Zoo-discuss at gisws.media.osaka-cu.ac.jp>
> *Subject: *Re: [ZOO-Discuss] Premature end of script headers:
> Hi Gérald,
> Thanks a lot for helping out here. I double checked and libxml2.dll is
> present under the same folder as zoo_loader.cgi and both of them are under
> OSGeo3W\bin (only difference is that I installed OSGeo4w under e:\programs
> which I don't think is the cause). I haven't tried the dumpbin yet which I
> will give a try though later today.
> By the way http://zoo-project.org/dl/zoo_loader_cmd.cgi is not accessible,
> can you provide it again?
> I really appreciate it.
> Thanks,
> Yingqi
> On Sat, Jul 10, 2010 at 2:49 AM, Gérald Fenoy <gerald.fenoy at geolabs.fr>wrote:
>> Yingqi,differe
>> thanks to answer.
>> It is a strange behavior that you get here. Indeed you should get the
>> ExceptionReport on win32 platform when running zoo_loader from the
>> c:\OSGeo4W\bin directory. Here you get only the header of the HTTP Response,
>> can you cofirm that the libxml2.dll is present in the same directory than
>> your ZOO Kernel ?
>> Did you try using the free Microsoft Visual C++ 2008 tools as dumpbin to
>> get more informations on dependencies ? If yes, can you please give us the
>> result here ?
>> The zoo_loader.cgi should run out of the box using the runtime provided on
>> the ZOO4W web page. Nevertheless, as the next ZOO Kernel will be able to run
>> directly from the command line, I recompile a new WIN32 version that you can
>> be downloaded from here : http://zoo-project.org/dl/zoo_loader_cmd.cgi .
>> Using this version, you should be able to run ZOO Kernel from the command
>> line, for instance :
>> cd c:\OSGeo4W\bin
>> .\zoo_loader_cmd.cgi
>> "serviceprovider=&metapath=&request=GetCapabilities&service=wps"
>> Here you should get the Capabilities XML Document displayed in your
>> terminal (and the header at the begining as you get before).
>> Please note that currently on win32 platform you still need to use the
>> serviceprovider and metapath parameters in your request. This will be
>> removed soon, as in the ongoing new ZOO Kernel version (unfortunately not
>> currently on the svn but we work hard on it to make it available next week).
>> Hope it helps,
>> regards,
>> ps: Yingqi, forgive for cross posting but I answered on zoo-discuss to.
>> Le 10 juil. 2010 à 07:28, Yingqi Tang a écrit :
>> Gérald,
>> All necessary dll are in place (under osgeo4w/bin) and executing
>> .\zoo_loader.cgi gives me following output
>> ContentType: text/xml; chartset=utf-8
>> Status: 200ok
>> Then the program stopped with a windows application crash dialog box. So
>> is that normal?
>> Is it possible to test GetCapabilities, DescribeProcess or so locally
>> instead of going through webserver?
>> Thanks
>> On Fri, Jul 9, 2010 at 5:08 PM, Yingqi Tang <anakintang at gmail.com> wrote:
>>> Thanks, i will give it a try.
>>> On Fri, Jul 9, 2010 at 4:21 PM, Gérald Fenoy <gerald.fenoy at geolabs.fr>wrote:
>>>> Yingqi,
>>>> you can also test the ZOO Kernel from command line using the following
>>>> commands :
>>>> cd c:\OSGeo4W\bin
>>>> .\zoo_loader.cgi
>>>> You should get an ExceptionReport returned here else an error window
>>>> displayed telling you what is the missing dll.
>>>> If you get the microsoft visual 9.0 you can also use its dumpbin tool
>>>> (dumpbin /dependents zoo_loader.cgi) after setting your environment
>>>> variables using the vcvars32.bat .
>>>> Hope it helps,
>>>> regards,
>>>> Le 10 juil. 2010 à 01:12, Gérald Fenoy a écrit :
>>>> Hi Yingqi,
>>>> using ZOO Kernel on win32 require the following dll :
>>>> libfcgi.dll
>>>> libcurl.dll
>>>> python25.dll
>>>> libxml2.dll
>>>> Hope it helps,
>>>> regards,
>>>> Le 10 juil. 2010 à 00:03, Yingqi Tang a écrit :
>>>> Hi all,
>>>> I am newbie to ZooWPS and I'm trying setup ZooWPS on my Windows 7 box
>>>> through ZOO4W. I read the doc and followed the steps below:
>>>> 1. Install OSGeo4W (I had that already for GDAL, QGIS, Apache etc.) and
>>>> load necessary library;
>>>> 2. I also installed the Apache through OSGeo4W too, which is running
>>>> fine (other cgi based app like MapServer is running fine through OSGeo4W's
>>>> bin folder)
>>>> 3. Copy those ZooWPS related files under OSGeo4W bin folder;
>>>> 4. Start the Apache server and type
>>>> http://host/cgi-bin/zoo_loader.cgi?Service=WPS&Request=GetCapabilities&Version=1.0.0in browser;
>>>> What I'm getting is an error message saying there is an internal server
>>>> error, and apache server log says "Premature end of script headers:
>>>> zoo_loader.cgi". I don't know what I did wrong and what else I can try to
>>>> make it work.
>>>> Can any one help me on this?
>>>> Thanks,
>>>> Yingqi _______________________________________________
>>>> Zoo-discuss mailing list
>>>> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
>>>> Gérald Fenoy
>>>> GEOLABS
>>>> Siège social :
>>>> Futur Building I
>>>> 1280, avenue des Platanes
>>>> 34970 Lattes
>>>> Tél. fixe : 04 67 53 67 37
>>>> Tél. portable : 06 70 08 25 39
>>>> Gérald Fenoy
>>>> GEOLABS
>>>> Siège social :
>>>> Futur Building I
>>>> 34970 Lattes
>> Gérald Fenoy
>> GEOLABS
>> Siège social :
>> Futur Building I
>> 34970 Lattes
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20100710/b63de649/attachment.html>
More information about the Zoo-discuss
