[ZOO-Discuss] ZOO Execute requests
Luca Delucchi lucadeluge at gmail.com
Sun May 16 01:21:51 PDT 2010
2010/5/12 James Sewell <James.Sewell at ardec.com.au>:
> Hey Nick,
> Thanks for the reply. I am working on CentOS. I used the cgic from the
> thirds directory (as mentioned DescribeProcess and GetCapabilities work fine
> via HTTP).
if you using python process maybe the problem is in your main.cfg,
where you can try to add
[env]
PYTHONPATH=<YOUR_PYTHONPATH>
> Cheers,
> James Sewell
cheers
Luca
More information about the Zoo-discuss mailing list
