[ZOO-Discuss] Zoo Kernel + WCS
Gérald Fenoy gerald.fenoy at geolabs.fr
Thu May 20 00:32:41 PDT 2010
Hello Angelos,
nice to hear that you use ZOO Kernel.
I never used WCS server with ZOO but you should be able to use WCS Request as input for a ZOO Process. You would use a Reference for this input and set the xlink:href value as the url encoded version of your WCS Request. Something similar to the following, added in your GET Request DataInputs value should do the trick (note that you can also use the XML POST request which should be easier) :
<InputName>=Reference at xlink:href=<YouUrlEncodedRequest>
Then in your ZOO Process you should get the string containing the WCS Response  in the "value" field of your input and can use it to feed your gdal processing.
Hope it helps,
best regards,
Le 19 mai 2010 à 18:17, Angelos a écrit :
> Hello everyone.
> I would like to ask if someone has ever used the Zoo kernel with a WCS service.
> I am trying to setup a scenario, in which a WCS service will provide
> the imagery to Zoo, and a gdal processing service will consume this
> image and post back results.
> I have already a working setup of Zoo in Linux, built with Python,
> PHP but not Java and JavaScript.
> Thanks
> Angelos
> Zoo-discuss mailing list
> Zoo-discuss at gisws.media.osaka-cu.ac.jp
> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
Djay
Just a ZOO Tribe member
More information about the Zoo-discuss mailing list
