[ZOO-Discuss] Static libraries in ZOO (libcgic)?
Luca Delucchi
lucadeluge at gmail.com
Fri Nov 5 01:06:01 PDT 2010
2010/11/5 Gérald Fenoy <gerald.fenoy at geolabs.fr>:
> Hi Luca,
Hi Gerarld
> I just checked and the ZOO-Kernel is well linked against the libcrypto on
> the Debian machine I used to run compilation tests. I also noticed that the
> GDAL developer package provided was linked against the libcrypto library.
> Please, can you confirm that your GDAL library is also linked against the
> libcrypto one ?
yes gdal library is linked against libcrypt
> By the way I think that it won't hurt anything if we add the -lcrypto to the
> Makefile.in during the linkage process.
> I've just updated the SVN source tree to add the -lcrypto stuff int he
> Makefile.in, can you please confirm that it solves your issue ?
Yes, you have solved the issue
> Hope to hear from you soon,
> Best regards,
thanks a lot
Luca
More information about the Zoo-discuss
