[ZOO-Discuss] Multiple supported mime type defintions
Soeren Gebbert soerengebbert at googlemail.com
Tue Nov 16 04:28:58 PST 2010
many thanks for the info.
Using yaml will indeed make many thinks much easier .... i eagerly
waiting for it!
Cheers
Soeren
2010/11/16 rldhont <rldhont at gmail.com>:
> Hi Soeren,
> It's a Bug! I already report it to Gérald, but the new config file based
> on YAML, I think, correct it.
> René-Luc D'Hont
> P.S: we need a roadmap
> Le 16/11/2010 13:13, Soeren Gebbert a écrit :
>> Hello,
>> does anybody know how to specify multiple<supported>  formats in a .zcfg file?
>> I have a lot GRASS GIS processes which support many input and output
>> data formats.
>> I thought defining multiple "supported" tags will solve this, but the
>> generated XML process description has only one format listed?
>> Any help is appreciated.
>> This is a part of my .zcfg file:
>>    [input]
>>    Title = Data source for OGR access
>>    Abstract =
>>    minOccurs = 1
>>    maxOccurs = 1
>>    <ComplexData>
>>      <Default>
>>        mimeType = text/xml
>>        encoding = UTF-8
>>        schema = http://schemas.opengis.net/gml/2.1.2/feature.xsd
>>      </Default>
>>      <Supported>
>>        mimeType = text/xml
>>        encoding = UTF-8
>>      </Supported>
>>      <Supported>
>>        mimeType = text/xml
>>        encoding = UTF-8
>>        schema = http://schemas.opengis.net/kml/2.2.0/ogckml22.xsd
>>      </Supported>
>>      <Supported>
>>        mimeType = application/dgn
>>      </Supported>
>>      <Supported>
>>        mimeType = application/shp
>>      </Supported>
>>      <Supported>
>>        mimeType = application/x-zipped-shp
>>      </Supported>
>>    </ComplexData>
>> Best regards
>> Soeren
>> Zoo-discuss mailing list
>> Zoo-discuss at gisws.media.osaka-cu.ac.jp
>> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
More information about the Zoo-discuss mailing list
